Is there a way to bypass the immobilizer on my disco2
Old Aug 14, 2015 | 02:19 PM
abran's Avatar
Sorry, Its Charlie that has it, not Alex...
Yes, if you plug up the holes you can run non SAI. If thats your route, you could take the screw in nipple connector at the head and plug weld the opening. The have a tapered end so it might be hard to find a suitable plug.
It would be better for you to use your non SAI heads on the build, but it might be too late for that. There is no difference in 4.0 and 4.6 heads.
Old Aug 14, 2015 | 02:55 PM
Charlie_V's Avatar
Yeah baby!!!
Okay, OP just PM me your name and address.
Old Aug 14, 2015 | 03:29 PM
abran's Avatar
Originally Posted by Charlie_V
Yeah baby!!! .
Insert Austin Powers voice...
For someone that claims to not be mechanical you sure are tackling a bunch of projects and modifications! Good work.
Old Aug 14, 2015 | 04:18 PM
Charlie_V's Avatar
Actually that job suiting my welding skill level perfectly.. Normally I first MAKE a hole by holding it in one spot too long, then I have to fill it. This was a cake walk.
But no, I never did more than change a belt and some oil before two years ago when I took a month to swap my engine, and I have no mechanical background at all. If it wasn't for the forums I would be ensconced in a new car every couple of years... and broke like everyone else.
nahtanoj
Mar 20, 2011 08:34 PM
drdabbles
Aug 17, 2010 07:37 PM
gsxrgessler
Jan 26, 2008 08:34 PM
humroot
Dec 24, 2007 02:25 PM
johnnybob06
Nov 18, 2007 09:05 AM
