Thinking of installing an oil pressure gauge
I went the glowshift route using the port above the oil filter. install was really easy and straightforward. Glowshift has the adaptor that fits without any drilling. I can't remember the size but will try to look it up. All seems to work well and accurate. Goes to 50-52 psi at cold start then settles in as things warm up.
I went a little crazy…
I always liked the Smiths dual oil pressure / coolant temp mechanical gauges ever since I bought a beater MGB in the early ‘80s.
Used the same Glowshift sandwich adapter quotes above with an AN3 adapter and SS beaded line to the gauge.
I cut up an Abran aluminum “T” and welded a tapped plug on one side for the temp probe.
Not exactly inexpensive, but it was a fun project and I like it.
