Thinking of installing an oil pressure gauge
Old Jan 9, 2022 | 08:09 AM
cvhyatt's Avatar
Default Thinking of installing an oil pressure gauge
What’s the conventional wisdom - sandwich adapter or plug sensor?
Anyone have a good write up for a noob?
Old Jan 9, 2022 | 10:00 AM
Alex_M's Avatar
Sandwich adapter works fine, but there's a cheaper way. There's a blank plug right above the oil filter. I pulled that out, drilled and tapped the middle of it with the correct pipe thread, and put the oil pressure sensor into that.
Old Jan 9, 2022 | 10:46 AM
dswilly's Avatar
I went the glowshift route using the port above the oil filter. install was really easy and straightforward. Glowshift has the adaptor that fits without any drilling. I can't remember the size but will try to look it up. All seems to work well and accurate. Goes to 50-52 psi at cold start then settles in as things warm up.
Old Jan 9, 2022 | 10:50 AM
dswilly's Avatar
The adapter part is M20 P-1.5 male to 1/8-27 NPT female thread adapter
Old Jan 9, 2022 | 01:42 PM
cvhyatt's Avatar
Thank you!!
Old Jan 9, 2022 | 10:35 PM
Tony Luna's Avatar
I went a little crazy…
I always liked the Smiths dual oil pressure / coolant temp mechanical gauges ever since I bought a beater MGB in the early ‘80s.
Used the same Glowshift sandwich adapter quotes above with an AN3 adapter and SS beaded line to the gauge.
I cut up an Abran aluminum “T” and welded a tapped plug on one side for the temp probe.
Not exactly inexpensive, but it was a fun project and I like it.
arains44
Feb 14, 2023 02:50 PM
Richard Gallant
Sep 14, 2018 09:54 AM
DiscoDos
Feb 12, 2012 06:55 AM
reddevildemo
Feb 2, 2010 10:51 AM
Fonzie
Oct 15, 2007 01:47 PM
