Throttle Body Heater - Why NOT to bypass it!
#21
I understand that, even below zero my intake air temp is above freezing because it is sucking in air from behind the radiator and headlamp.
Have you driven on long highway trips in high humidity low temp conditions?
Do you guys have freezing fog?
No one is saying it is going to happen each and every time you drive, but it is enough of a concern that it was installed at the factory.
You can do what you want, but to recommend that people by-pass it and never fix it is just wrong in my opinion.
#22
#23
on
I don't know a lot about the Discovery yet, though I am now preparing to buy one, But, am I correct, the hose to this throttle body comes from that third hose outlet on coolant thermostat housing above and to side of radiator? If that is the case, and if one converts the OEM thermostat to more traditional temperature thermostat housing (having only two outlets on it), what do you connect that third hose to, the one that goes to the throttle body heater?
adolfojbonilla
03-13-2016 09:59 PM
