Tire Size??
Old Dec 2, 2008 | 07:25 PM
mooal5's Avatar
Default Tire Size??
Hey guys I have a 96 disco currently are running 235/70/16 I believe to be stock size. It is time for new tires and I am thinking about changing sizes going a bit bigger. I have a all stock set up. I want a bit wider tire and a bit taller. I am thinking 245/70/16. What are your thoughts? I want all terrain. Thanks.
Old Dec 2, 2008 | 07:39 PM
Default RE: Tire Size??
245/75/16 will fit just fine with a 100% stock truck.
And yes, 235/70/16 is factory size.
Old Dec 2, 2008 | 08:25 PM
discoxd's Avatar
yeah you should not have any issues running 245/70s or even 245/75s...
Old Dec 2, 2008 | 11:47 PM
hazletbassist89's Avatar
If you plan on off roading at all I would recommend upgrading your suspension to a 2" OME lift and running 235/85s or 265/75 if you run mostly mud. Both of these are roughly 32" tires.
Old Dec 3, 2008 | 10:14 AM
Ditto.
With your old warn out suspension, if you go ogg roading thru dips and ruts, you will rub or damage a 245/70/16.
Seriously consider redoing your suspension.
Old Dec 3, 2008 | 10:48 AM
discoxd's Avatar
+1... suspension will make a world of difference in how ur rover drives and rides and looks and everything... its not difficult to do with basic tools and not excessively expensive...
jigray3
Oct 14, 2010 06:54 PM
jigray3
Oct 9, 2010 09:27 AM
samsly
Tires
Feb 27, 2006 07:01 AM
chefman
Jan 18, 2006 10:15 AM
jhstew1
Jun 14, 2005 03:41 PM
