Tire size
Old Apr 11, 2014 | 01:25 PM
abran's Avatar
Default Tire size
I have 16x8 rims and want to put 215/85/16 tires on them. Will this work?
This is for a non lifted 2004 D2.
Thanks.
Old Apr 11, 2014 | 01:36 PM
ZGPhoto's Avatar
IMO that's pretty skinny for an 8" wide wheel, even 235 is a bit narrow. You should be fine for road driving though(if it fits)
Old Apr 11, 2014 | 02:25 PM
0304Disco's Avatar
What's the reason for such a narrow tire?
Old Apr 13, 2014 | 12:21 AM
abran's Avatar
Overall, I like the look. Was also told that gas mileage is better and that Off raid performance would not suffer.
Old Apr 13, 2014 | 12:54 AM
ScreamingLife's Avatar
265/75R16 will just squeak under there without a lift, but will rub at full lock. I'd think 215/85R16 will be VERY narrow. 245/75R16 is probably be your best bet.
Old Apr 13, 2014 | 09:29 PM
abran's Avatar
Thank you all for the suggestions.
I still want NARROW! Im going to see if I can get a used tire and mount it to see what happens. I will update with photos once I get the misfires sorted and the major oil leak fixed.
Old Apr 13, 2014 | 09:53 PM
dr. mordo's Avatar
I have always been told that gas mileage suffers with taller and/or heavier tires. 215/85 is certainly much taller and heavier than the stock size.
And, as stated above, 215 is very narrow for an 8" rim.
I went with 245/70r16, and they are about the same size as stock while a bit narrower. You should be able to get a 235/75r16 on the rim, but I don't think they make them.
Trying a used tire the smart way to go if you have to try it.
Old Apr 14, 2014 | 12:10 PM
Big Jim Swade's Avatar
They will work if you can get the beads to seal when you're mounting them. They will be more susceptible to sidewall damage when offroading. I would really go with something wider, at least 235's
Old Apr 14, 2014 | 12:26 PM
velija's Avatar
Don't mind me if I get in on this
I as well have the 16" wheels and just put an ome 2" lift on it
What's the biggest tire I could go with with these wheels
Old Apr 14, 2014 | 02:05 PM
Motorhead1's Avatar
235/85-16 aggresive mud tire
TF medium 2" lift kit = 3" overall lift from stock, on my 01' D2
jigray3
Oct 14, 2010 06:54 PM
jigray3
Oct 9, 2010 09:27 AM
samsly
Tires
Feb 27, 2006 07:01 AM
chefman
Jan 18, 2006 10:15 AM
jhstew1
Jun 14, 2005 03:41 PM
