Trans Filler and Drain Plug
Old Apr 29, 2007 | 11:59 PM
jacksyachts's Avatar
Default Trans Filler and Drain Plug
OK.....don't make fun of me, but what is used to take out the trans filler and drain plug on a Disco2 2002?
And how are the driveshafts lubricated? Thanks in advance.
Old Apr 30, 2007 | 12:06 PM
Default RE: Trans Filler and Drain Plug
How many miles on your truck and when was the last tranny filter change done?
As for the drive shafts, they are lubed with a grease gun, and you will probably have to replace the 2 u-joints in the front double cardon housing where it attaches to the t/case if they don't have grease fittings.
You might want to send me your tele number and a good time to call you and I will describe what you need to look for.
Mike
mikeljacobs@comcast.net
Old Apr 30, 2007 | 12:22 PM
BogdenZ's Avatar
The drain and fill plugs are removed/installed with an allen/hex keywrench. I can't recall the exact size but, if you have a decent set of allens, you'll have what you need.
Old May 1, 2007 | 03:49 PM
StevenDiscoII's Avatar
ORIGINAL: Disco Mike
When I replaced mine two front U-jonts at about 90K, I used the ones with a grease fittings, which I have screwed in quite deep. Seems it worked since they did clear the U-joint cage.
Now, I hope they are still in place (the grease fittings that is) [sm=smiley23.gif]
Old May 2, 2007 | 11:01 AM
Mike...I have 65k on the Disco. I do have grease fittings. Any particular grease I should use? As for the tranny filter I am unsure as I bought her with 53k and no service history. After reading the posts on trans oil replacement, I am thinking about doing the gradual change....ie drain, fill with 3 quarts, start her up, go through the gears and then fill til the stuff seeps from the fill hole. Then do the same again in a couple of months. Any thoughts?
Old May 2, 2007 | 11:47 AM
If you have a grease gun, use whatever is in it, if you have to go buy one, also buy a tube of Mobil 1's gease oe any other synthetic that you can find, they last longer the regular grease.
Mike
Old May 2, 2007 | 11:49 AM
Thanks Mike
Snafu / Disco Fries
May 9, 2011 07:56 AM
mwindth
May 2, 2010 03:47 PM
Robmcin
Jun 24, 2009 02:22 AM
fp360spidr
Jul 22, 2007 03:05 PM
imag
May 12, 2006 07:59 PM
