Trans not engaging in reverse or drive.
03 disco with auto trans. It is not engaging when shifting from park to reverse or drive. This happens most of the time. Some times it works correctly. Some times it takes a few seconds then other times it will not engage at all.
Is it a temperamental XYZ switch? Or an adjustment in the shift linkage? Possibly in the t-case shift linkage (shift position switch?). Or something with the brake switch (I read something some where)?
It could be the XYZ switch. Saw you previous post that you having problem with 4th. XYZ switch, not properly installed will do all those problem you are having. Loosen and tighten the xyz and move it a fraction each time until you get those corrected. Its a bit tricky and sometimes you wont have any reverse if not properly marked or wont go up to the right lever setting.
My thought was the Transfer case. The Rover I bought would go through all the gears and all the lights would indicate, but nothing happened.
