Trans not engaging in reverse or drive.
Old Jan 12, 2018 | 11:40 AM
James Weishaar Jr.'s Avatar
Default Trans not engaging in reverse or drive.
03 disco with auto trans. It is not engaging when shifting from park to reverse or drive. This happens most of the time. Some times it works correctly. Some times it takes a few seconds then other times it will not engage at all.
Is it a temperamental XYZ switch? Or an adjustment in the shift linkage? Possibly in the t-case shift linkage (shift position switch?). Or something with the brake switch (I read something some where)?
Old Jan 12, 2018 | 12:11 PM
LR03NJ's Avatar
It could be the XYZ switch. Saw you previous post that you having problem with 4th. XYZ switch, not properly installed will do all those problem you are having. Loosen and tighten the xyz and move it a fraction each time until you get those corrected. Its a bit tricky and sometimes you wont have any reverse if not properly marked or wont go up to the right lever setting.
Old Jan 12, 2018 | 12:28 PM
Best4x4's Avatar
I’ve also personally found the older tan XYZ switches to not be as picky when adjusting them vs the newer style black ones.
Old Jan 12, 2018 | 12:39 PM
LR03NJ's Avatar
Best4x4, my experience was the other way around. The newer black ones was straight on when I installed and minor adjustment but the tan, gosh! I probably rounded the teeth inside twice, LOL! .
I think I used the black ones on the '03
Old Jan 12, 2018 | 01:14 PM
Sandman614's Avatar
Does it make a grinding noise when shifting back to park when it doesn't engage?
Old Jan 12, 2018 | 01:23 PM
I have adjusted a couple times. I have all indicator lights when shifting through the gears. and all letters on the dash when shifting. I will play with it some more this weekend. It is the tan switch. and no noises when going into park.
Old Jan 12, 2018 | 03:13 PM
Sandman614's Avatar
My thought was the Transfer case. The Rover I bought would go through all the gears and all the lights would indicate, but nothing happened.
Old Jan 12, 2018 | 04:24 PM
jfall's Avatar
Crawl under there and open the trans filler up and check the level.
Probably been leaking out slowly.
Old Jan 12, 2018 | 05:13 PM
All fluids are good. t-case works great. When I shift into gear I get no noise, no jerking, nothing. I definitely know when it shifts in.
sickvehicle
22
Oct 5, 2010 09:20 PM
microbc
Jun 23, 2009 01:09 PM
tango123
Feb 24, 2009 03:36 PM
philo73
Dec 17, 2007 02:00 PM
db1047
Apr 27, 2006 08:10 PM
