Transfer Case
Old 09-04-2013 | 04:13 PM
Braxton's Avatar
Sorry about that. They came off the same year model as the one I own, 2002.
Old 09-04-2013 | 09:30 PM
floundering's Avatar
A 2002 should not have a CDL t-case in it OEM. But perhaps it was a CDL case from a 1999-2001 that replaced the OEM on the donor vehicle, same as you're doing now. Re-read DiscoMike's reply. But in any event, don't think there would be any compatibility issues. The 2002 wiring may still have the mate to the "extra" connectors for the donor t-case. Take a pic and post so we can confirm the extra connectors!!!
Old 09-05-2013 | 02:23 PM
Braxton's Avatar
Here is the pic of the connectors on the replacement TC, mechanic says my DII does not have the wiring for these connectors.
Old 09-05-2013 | 07:07 PM
CDL sensor. See attached 11 is for warning lamp and 12 is a detent plug. Looks like your donor may have had a CDL linkage installed in it's previous life. That empty bolt hole in the lower left of your pic should have a bolt in it. The bracket for the CDL attaches there using those bolt holes. Dismantler probably remove the shift linkage and left the holes empty.
Old 09-06-2013 | 05:04 PM
Braxton's Avatar
Thanks identifying the connectors. I'm still not clear whether this TC will work with on my DII, would hate to have it installed then it not work.
Old 09-07-2013 | 08:41 PM
Mel Morales III's Avatar
5th Gear
Originally Posted by Disco Mike
Do you have a 2 cable shifter or one with mechanical arms like from a D1?
The difference in length is not worth worrying about.
Hi mike. Only have one. After getting the new tranny and tcase installed, it wont go into gear - just high revs. It wont engage. What gives? Do i need to reprogram the computer? Please let me know. Thanks!
imag
05-12-2006 07:59 PM
adowgiert
08-27-2005 04:53 PM
garnstar
08-03-2005 01:45 AM
Loose_Screws
07-22-2005 12:13 AM
Smokeyone
06-04-2005 03:11 AM
Quick Reply: Transfer Case
