Transfer case swap - What else should I do while I am in there?
Old Feb 18, 2016 | 02:20 PM
jashof's Avatar
4wd High
Default Transfer case swap - What else should I do while I am in there?
My transfer case is shot--wont shift into low or hold fluid and it has metal chunks coming out at last service.
My plan is to swap it out with an reman transfer case with a CDL, and add an ashcroft linkage and shifter, and an SRD500070 SLABS ECU at the same time.
I ordered up the parts, but I am wondering what else I should do while I am in there generally? Are there other bolt kits, flanges or seals I should be looking at if I am going to be taking the transfer case off anyway?
Thanks
Old Feb 18, 2016 | 02:52 PM
coors's Avatar
Thanks
If you do not have a serviceable prop-shaft I would most certainly add that to the PO.
Does the tranny need to be pulled to remove / replace the T-case? My guess. Is no. But if so, engin rear main seal, tranny input out put shaft seal and while your there new fluid and filter.
Old Feb 19, 2016 | 08:58 AM
Alex_M's Avatar
The trans does not.
FFJ
Nov 11, 2015 11:53 AM
MattyJ2000DiscoII
Dec 19, 2012 09:32 PM
grandkodiak
May 16, 2011 01:57 AM
XxRoverAllOverxX
Oct 4, 2010 02:47 PM
oysterhead
Apr 10, 2010 08:06 AM
