Tricky Dick - Head Gasket Replacement
Old Dec 3, 2019 | 11:47 PM
  #21
Brandon318's Avatar
Originally Posted by Friday Night Disco
That sounds like you still have air pockets in the cooling system. If you are having to add coolant every couple days that is an indicator of a bad HC.
But the pressure is what's confusing me. Why wouldn't the pressure relieve itself through the expansion tank? I might be understanding the function of the expansion tank cap correctly.
Old Dec 4, 2019 | 09:51 AM
  #22
Friday Night Disco's Avatar
That is not the functionality of the expansion tank. What is happening is that pocket of air is circulating in your cooling system and it is causing it to pressurize. I would suggest next time, lift the expansion tank above the radiator (when the coolant level is low), let it sit over night and when the truck is stone cold, take the cap off and top off the coolant. Do this till the coolant level does not decline any more.
Old Dec 7, 2019 | 03:26 PM
  #23
UPDATE
6 hours into tearing things apart
Removed upper plenum
Drained coolant
Removed alternator
Removed/ set aside (still connected) AC compressor
Removed/ set aside (still connected) power steering & ACE pump
Removed pulleys
Removed coil packs
Removed intake
Removed all brackets for alternator, AC, pump
Removed SAI
Removed valley pan
Issues
Broke 3 of the upper plenum bolts
Broke breather tube on passenger side valve cover
Broke passenger side SAI trying to remove
I need to go buy triple square sockets for valve covers and exhaust maniford
Old Dec 8, 2019 | 01:43 PM
  #24
XRAD's Avatar
Nice work!
I used a 5/16 12pt for the valve cover bolts
12pt 12mm universal for the exhaust bolts
5/8 6 pt universal for the head nuts.
Old Dec 8, 2019 | 02:52 PM
  #25
Originally Posted by XRAD
Nice work!
UPDATE
I would say I am officially at 8 hours tearing down and I am 90% done
I went and bought a univeral kit at Home Depot for $49, it has 5mm - 16mm
REMOVED Valve covers
REMOVED Exhaust Manifold bolts
Found a SAI locally to replace the one I broke
PENDING drill out the (3) snapped studs on the intake manifold
PENDING replace breather on passenger side valve cover
PENDING remove heads
Old Dec 8, 2019 | 04:16 PM
  #26
Extinct's Avatar
That engine is pretty clean, good job so far. Good tools also.
Old Dec 11, 2019 | 05:52 PM
  #27
UPDATE
Removed drivers side head
ISSUE
Rounded one bolt on drivers side and perplexed how to get it out. Thinking of drilling the head of the bolt off, remove the head, and attempt to PB Blaster and vice grip the remaining bolt out. Thought??
Broke the nipple off the top of the radiator when removing head bolts...
Old Dec 11, 2019 | 09:04 PM
  #28
Extinct's Avatar
Get a 6 point impact socket on that bolt head, it will come out.
Old Dec 11, 2019 | 09:31 PM
  #29
tried 6 and 12 on impact gun. Would not budge got frustrated and ended up rounding head of bolt
Old Dec 12, 2019 | 06:09 AM
  #30
mln01's Avatar
Others have reported good results with a bolt like the one linked below.
Irwin Tools BOLT-GRIP Extractor Expansion Set, 5 Piece, 394002
Amazon Amazon
