Tricky Dick - Head Gasket Replacement
UPDATE
Still having same issue with codes
Tried backing out bolts on exhaust manifold and tightening them per pattern and torque specs in RAVE. No luck same issue
Tried checking bolts on flange. No luck same issue
NEXT STEPS
I need to do a smoke test
Thinking about trying vacuum cleaner on tail pipe first
NEXT STEPS
I like what you are throwing down. I want to try the vacuum cleaner first before any Seafoam.
Just read that the codes could be caused by the new PCV308 that I installed, or rather too much air is getting into the intake bypassing the MAF. The exhaust leak may be an issue but, not the root cause of the codes. I will look into this more and report back.
