Tricky Dick - Head Gasket Replacement
Old Dec 20, 2019 | 02:51 PM
  #51
Friday Night Disco's Avatar
UPDATE
Exhaust leak fixed
Codes gone
Coolant leaks fixed
I am going to run the truck for the next couple of days close to home and watch for any issues
Old Dec 23, 2019 | 09:42 AM
  #52
WaltNYC's Avatar
Congrats! Well done.
Old Dec 23, 2019 | 10:17 AM
  #53
Small update, still getting a small exhaust leak at the headers and causing a code. I think I just need to back the exhaust manifold bolts out a little bit and retighten
Old Dec 23, 2019 | 07:42 PM
  #54
UPDATE
Still having same issue with codes
Tried backing out bolts on exhaust manifold and tightening them per pattern and torque specs in RAVE. No luck same issue
Tried checking bolts on flange. No luck same issue
NEXT STEPS
I need to do a smoke test
Thinking about trying vacuum cleaner on tail pipe first
Old Dec 23, 2019 | 07:52 PM
  #55
Best4x4's Avatar
If you need to smoke test the exhaust some good old Seafoam will show you any exhaust leaks lol.
Old Dec 23, 2019 | 08:01 PM
  #56
I like what you are throwing down. I want to try the vacuum cleaner first before any Seafoam.
Old Dec 23, 2019 | 10:13 PM
  #57
mollusc's Avatar
Did you put copper coat spray on the exhaust manifold gaskets?
Old Dec 23, 2019 | 10:37 PM
  #58
negative just used the Lucky8 gaskets and torqued per RAVE
Old Dec 24, 2019 | 06:24 AM
  #59
mollusc's Avatar
Well you might want to try it. The copper coat can help seal tiny surface imperfections.
Old Dec 24, 2019 | 08:45 AM
  #60
Thanks for the feedback. Let me isolate the leak and we will go from there
Just read that the codes could be caused by the new PCV308 that I installed, or rather too much air is getting into the intake bypassing the MAF. The exhaust leak may be an issue but, not the root cause of the codes. I will look into this more and report back.
