u-joint
Old Jan 1, 2008 | 06:52 PM
mwyrick45's Avatar
Default u-joint
Is it easy to replace the u-joint in the front driveshaft on my own??? Ive got a bad vibration and Id like to avoid ruining my truck.
Old Jan 1, 2008 | 07:17 PM
jkid's Avatar
Default RE: u-joint
There are 3 u-joints on the front shaft. With the right tools and somebody to help you if you've never done it before, then yes it is easy. If you have to ask, then it will probably be a huge PIA. The easiest thing to do is take it off yourself (make sure that you mark everything well so that it goes on exactly the same way you took it off and everthing lines up correctly) ,take it to a transmission shop and let them replace the joints. When you put it back on, torque is correctly and use some thread lock on the bolts. Or just drop the truck off at the transmission shop and let them take care of it.
Old Jan 1, 2008 | 07:33 PM
mwyrick45's Avatar
Default RE: u-joint
thanks
Old Jan 1, 2008 | 11:35 PM
discoken's Avatar
Default RE: u-joint
Is replacing the u-joint for all discoverys or just the D2's? Just wondering cause I have a D1 and not sure if the u-joints were ever touched. If so, about how much would a tranny shop charge for this service? Thanks.
Old Jan 2, 2008 | 05:02 AM
Adz's Avatar
Adz
Default RE: u-joint
discoken - D1's have UJ's in their prop's too - 2 in the front and 2 in the rear. They need regular greasing, I do mine about every 6k service and also regrease them every time I use it off road.
Replacement parts for the bearings anc cups in the UK are about £8 delivered from http://www.paddockspares.com although postage will be a bit more for you guys in the USA if you buy them from over here.
Alternatively, instead of fiddling about replacing the UJ cups, bearings and spider you can buy a ready assembled new prop-shaft from the same place (the front one for my Defender and the tool to easily undo the prop bolts came to about £80 GBP delivered and came with new bolts at no charge) and replace the whole prop in about half an hour.
Cheers,
lowill
Nov 30, 2006 11:29 AM
pom1987
Apr 20, 2006 04:37 AM
RobFrey1
Sep 22, 2005 02:12 AM
jasonsLR
Aug 11, 2005 01:21 AM
Bene
May 23, 2005 01:00 PM
