Unknown plug above oil drain
Old Sep 16, 2018 | 09:30 AM
BMF175's Avatar
Default Unknown plug above oil drain
So I was under my disco this morning. I was double checking a couple things. Mainly making sure there was no leak in ATF from the recent servicing that was performed. I noticed this black rubber plug was only half way holding on. So I pull I completely off and clean it and try and get it all the way in the hole it is supposed to be in.
I don’t know how long it’s been halfway open.
My my question is. Should I be replacing any fluid that this plug protects? What is the primary function of this plug and why is it so cheaply made to where it can be pushed out by pressure?
the greenish fluid you see collecting at the bottom of the transmission pan... I recently went to a mechanic and he filled the AC system with a dye so the leak can be located. Is there any other liquid that would be leaking from that location? I’m assuming it the dye and I have a leak in the cabin possibly the heater core.
What at do you guys think?
as always thanks for the help.
Old Sep 16, 2018 | 09:45 AM
Twix's Avatar
It just allows the flex plate to be inspected and to keep sand and grit out of the bell housing
Old Sep 16, 2018 | 12:59 PM
The Deputy's Avatar
The rubber plug is installed in the access hole, for the removal of the flex-plate bolts, there is one on each side of engine/bell-housing, it just keeps dirt from entering the bell-housing. Usually, once they get oil soaked...they no longer fit. They are available through Atlantic British.
Edit...just saw the second part of your post...
If you are using green anti-freeze...that area on the trans pan is most likely anti-freeze, coming from either the head gaskets or valley pan gasket. Are you losing any coolant from the reservoir?
Brian.
Old Sep 16, 2018 | 01:15 PM
BMF175's Avatar
Yes I am using green antifreeze.
whete is the valley pan gasket? What section on the rave should I be looking?
also just looked for the plug on Atlantic British. Does anybody know it’s actual name or what it is listed under?
Old Sep 16, 2018 | 01:20 PM
lower intake manifold to heads/block gasket = valley pan
Old Sep 16, 2018 | 01:21 PM
BMF175's Avatar
Awesome thanks
Old Sep 16, 2018 | 01:27 PM
BMF175's Avatar
Found it on eBay.
“Rear Oil Pan Grommet”
Old Sep 16, 2018 | 01:32 PM
BMF175's Avatar
I knew I had a leak but didn’t realize it was leaking that much. I’ll have to check the back side of the engine.
Old Sep 19, 2018 | 02:36 PM
DiscoBuckeye's Avatar
Originally Posted by BMF175
Found it on eBay.
When I did the ebay search for that a while back they were almost double what I could get them at Atlantic British.
TRIARII
May 2, 2022 08:05 AM
jvarnadoe
Jul 9, 2019 08:05 PM
A5scott
Nov 24, 2017 04:50 AM
lancefitzgiben
Sep 7, 2017 11:16 AM
01disco2
Dec 6, 2013 12:44 PM
