Upper radiator tee fitting disintegrates?
Old Feb 8, 2016 | 10:46 PM
  #41
LR03NJ's Avatar
Originally Posted by Joemamma1954
I know it is kind of expensive but should be a permanent fix. Found one at Ferguson's Plumbing also. I have looked at a lot of different tees, and like the looks of this one. I already have the bleed valve, drill and taps, just need to get the tee.
That will be a great mod project. The cheaper homedepot is thin and cant handle the bleed valve. Unless you press it inside and good amount of epoxy.
Old Feb 8, 2016 | 10:49 PM
  #42
number9's Avatar
Originally Posted by LR03NJ
That one has too much gold in the brass alloy. And rather than spending extra bucks on a bleed "valve" that will eventually go bad, consider tapping to accept a plug with o-ring similar to OEM design.
Old Feb 13, 2016 | 12:28 AM
  #43
DiscoCam's Avatar
I just remembered that I actually made a YouTube video about this a few months back. Maybe it could help some people who are thinking about doing the copper tee conversion.
Old Feb 13, 2016 | 05:48 AM
  #44
Alex_M's Avatar
Originally Posted by jasonstaczek
Fascinating! All that data and you can't find the crucial information: it will fail in its intended use environment in approximately 10 years, leaving you stranded and swearing by the side of the road, with lots of environmentally damaging fluid product spilling on to the earth!
I'd just like to note that, while propylene glycol may be detrimental to the neighbors kid and your award winning teacup poodle Brutus, its not harmful to the environment in any way. It's a naturally occurring substance and is in a wide range of things including lots of foods, just in MUCH smaller doses.
Also, running with no thermostat My man, spend $60 and throw an in line stat in there. That's pretty bad for your engine and your gas mileage.
While we're on the topic of alternate hose tees, I had for a time a grey (high temp) pvc tee fitting from the local hardware store that worked perfectly. If you really wanted to add a bleed valve then you could do the same thing as the inline mod and add one of those inline temp gauge ports with a 3/8 npt plug with a wing style head. Probably around $15-20 for all three pieces said and done.
Old Feb 13, 2016 | 09:03 AM
  #45
number9's Avatar
Default Ethylene Glycol
You are referring to the other glycol that's also used in potable water system antifreeze. Ethylene glycol is used in most engine coolants, it can cause death if ingested by human animals as well and possible environmental damage.
Old Feb 13, 2016 | 09:42 AM
  #46
Alex_M's Avatar
Oh, whoops. Guess i should stop taking my antifreeze to the land fill in 5 gal buckets :/
lrjon
Feb 27, 2024 04:27 PM
JaySun
Dec 5, 2019 01:49 AM
LR03NJ
Nov 25, 2015 07:16 PM
NickAdams
Dec 26, 2012 12:16 PM
onewingman
Oct 12, 2012 01:56 PM
