"UZI" Air compressor sound....
Old May 4, 2012 | 05:57 PM
CANAMDiscovery's Avatar
Default "UZI" Air compressor sound....
So every 11-12 seconds (by my count) there is an air compressor "uzi" sound coming from my engine that lasts for a second each time. At first my reaction was to check the air compressor for the SLS air suspension in the rear...no sound coming from there.
I have no secondary air SAI on the truck, so what could be possible culprits?
Old May 4, 2012 | 06:11 PM
jafir's Avatar
A/C compressor cycling on and off due to low refrigerant maybe?
Old May 4, 2012 | 06:23 PM
Thanks...Thats a possibility... Have not ran the AC in 6 months or so...
Any ideas on how to check the refrigerant level. I will search, but will more than likely go to the shop for this one.
Old May 4, 2012 | 09:47 PM
You need gauges. You can watch AC compressor clutch. Or just turn off and see if it stops the cycle. One trip to the dealer for this will pay for a set of gauges.
SLS compressor and valves are not as noisy, but here's pix of them just in case. Disconnect C0811 for testing, kills pump and three valves.
File Type: pdf
File Type: pdf
jycsalas
May 23, 2019 03:02 PM
ljdiscovery
May 28, 2014 09:46 PM
amybc96
Sep 26, 2013 06:42 PM
mvjimenez
Jun 12, 2010 10:25 AM
LandRoverDiscoDos
Apr 7, 2007 04:49 PM
