Vibration at 60-65mph under acceleration
Old Mar 5, 2014 | 11:47 AM
FlyingZebra34's Avatar
Default Vibration at 60-65mph under acceleration
Trying to figure out if it's the tires needing balancing, or the front driveshaft needs balancing, or the front output bearing that is going to **** on the t-case is causing it.
Thanks for the input.
Old Mar 5, 2014 | 12:05 PM
dusty1's Avatar
or mounts
cdl test w/o front shaft to eliminate that
Old Mar 5, 2014 | 04:26 PM
You mean like the motor and tranny mounts? I replaced them all like 2 years ago from rock auto and I think they are already toast.
I didn't think those could cause vibration.
Old Mar 5, 2014 | 04:42 PM
dusty1's Avatar
yep and yep.......2 years is a very short life expectancy,though
Old Mar 5, 2014 | 06:35 PM
TripleThreat's Avatar
Is the vibration high frequency or low frequency? A driveshaft vibration would likely be a significantly higher frequency than a tire out of balance.
Old Mar 5, 2014 | 10:18 PM
It feels bumpy. This issue started up like 2 months ago when my driveshaft exploded.
I've since rebuilt it and my buddy at a driveshaft shop said the balancing was OK. Thing is I kinda hit some big bumps so a number of things could be wrong all at the same time.
I'm replacing the front bearing on the t-case next week since there is play in it but its been like that forever and it didn't vibrate before.
Old Mar 5, 2014 | 10:20 PM
Well they are cheap Chinese crap. That's probably what I deserve. I know better...
After I rebuild the case and double heck the shaft and tires I'll look at the mounts. I hated swapping those out last time.
Dave2345805
Off Topic
Aug 2, 2015 09:09 PM
ge234
Nov 1, 2014 07:23 AM
jfall
Jul 3, 2012 08:38 AM
northernlilywhite
Nov 11, 2011 09:54 PM
camomile
Freelander
Dec 6, 2010 09:14 PM
