Warm air when air conditioning should be on
I have an A/C question. The driver side seems to be working just fine (it blows Ice Cold) but the passenger side is warm. I tried to set the passenger side as low as it will go but no response. Not that I care if my passenger is comfortable, but don't want this to be sign of things to come.
As a side note, I did start to notice a ''refrigerant sound'' becoming more pronounced in the dash. (if that makes any scene) It kind of reminded me of how loud the window shaker a/c units sound when they kick off and you can hear the refrigerant in the coils still moving.
Be dang sure you wire them so the air is pushed into the radiator, not blown out the grille (like my PO did). As for both fail at once, it is not uncommon for owners who don't pay attention to such things to "hear" the fan running and assume it is "both running", very common in the W124 Mercedes tribe.
I think these are the ones I used, you just have to reverse the blades.
http://www.ebay.com/itm/Universal-12...70990883494%26
I wired them to the stock wire loom and bought two pieces of aluminum flat stock at HD 1/4 x 2 x 36", mounted the flat stock to the truck (l to r) using existing holes and them mounted the fans to the flat stock.
I don't like those clips the give you to stick threw the radiator, I wanted something more ridged.
mpompliano
Freelander
07-31-2012 06:13 PM
