Water Pump
here it is for $80 Airtex AW9369 New Water Pump | eBay
this would also be a good choice as the clutch and fan are all one unit on an 03/04.
Land Range Rover Discovery Radiator Fan Clutch Fan Blade Water Pump Kit 4 PC | eBay
as I asked earlier what is the difference with the impeller material?
the bearing & seal are not going to last any longer because the impeller is brass probably less because the brass impeller is twice the weight of a steel one.
it doesn't have anything to do with electrolysis, because LR has already mixed steel, aluminum, brass, lead & iron. so it isn't going to help with that.
so your bearings and seal will still go but you will have brass for the scrap pile.
The only time brass or bronze in use in other types of pumps is if it has potable water running thru the pump i.e drinking water.
The impeller design (surface area) may differ from the oem stamped and folded version. In that case, flow would be more for same shaft rpm. Agree on the electrolysis not an issue. I figure if the one on my 97 lasted 14 years, the idea that I will still have the truck in another 14 is questionable.
Team140
08-30-2009 09:41 AM
