Water Pump
Old Sep 20, 2013 | 07:50 AM
drowssap's Avatar
here it is for $80 Airtex AW9369 New Water Pump | eBay
this would also be a good choice as the clutch and fan are all one unit on an 03/04.
Land Range Rover Discovery Radiator Fan Clutch Fan Blade Water Pump Kit 4 PC | eBay
Old Sep 20, 2013 | 08:13 AM
dusty1's Avatar
^that is a good deal, nice find. I wish I had seen that last week
Old Sep 20, 2013 | 09:08 AM
pinkytoe69's Avatar
Originally Posted by drowssap
Airtex makes two...cheap and expensive. That is the cheap one without the brass.
Old Sep 20, 2013 | 09:46 AM
drowssap's Avatar
as I asked earlier what is the difference with the impeller material?
the bearing & seal are not going to last any longer because the impeller is brass probably less because the brass impeller is twice the weight of a steel one.
it doesn't have anything to do with electrolysis, because LR has already mixed steel, aluminum, brass, lead & iron. so it isn't going to help with that.
so your bearings and seal will still go but you will have brass for the scrap pile.
The only time brass or bronze in use in other types of pumps is if it has potable water running thru the pump i.e drinking water.
Old Sep 20, 2013 | 09:51 AM
The impeller design (surface area) may differ from the oem stamped and folded version. In that case, flow would be more for same shaft rpm. Agree on the electrolysis not an issue. I figure if the one on my 97 lasted 14 years, the idea that I will still have the truck in another 14 is questionable.
Old Sep 20, 2013 | 10:03 AM
drowssap's Avatar
there a possiblity
Old Sep 21, 2013 | 09:01 AM
expedio2005's Avatar
This says it's for up to an '02. This will still fit on an '03-04?
A5scott
May 18, 2015 06:34 AM
discoboy
Dec 20, 2012 02:24 AM
Savannah Buzz
Jul 21, 2011 08:02 PM
Team140
Aug 30, 2009 09:41 AM
QUINCYSDISCOVERY3
Jun 8, 2008 06:50 PM
