Water pump type?
Old Jan 14, 2013 | 10:02 AM
flybyjlane's Avatar
5th Gear
Default Water pump type?
Hey everyone...
I am going to be replacing my timing cover gasket on my '02 D2, and was advised to replace my water pump as well. Atlantic British has a generic brand and an OE type pump. Does anyone have any experience with the generic version, or is it best to stick with the OE? Thanks
Old Jan 14, 2013 | 10:10 AM
drowssap's Avatar
I run both on my truck and have had no problems, I have been running it for two years & approx. 30k.
If your that far; depending on your milege you may want to do the timing chain and oil pump, your already there.
It would be a shame to have to drop the oil pan and rip the front of the engine apart in a couple of months for something you could replace while its was open.
Old Jan 14, 2013 | 10:30 AM
Buy the water pump by Airtex with the brass impellor, great pump and warranty.
Old Jan 14, 2013 | 11:16 AM
D1 pump on left, D2 pump on right, they are identical except for the stop leaks build up. Note impeller. An after market pump with a larger bronze impeller would be a plus. Also, while it is under the wrench, consider a 180 soft spring thermostat.
Attached Thumbnails Water pump type?-p1030593.jpg   Water pump type?-p1030596.jpg   Water pump type?-land_range_rover_classic_discovery_defender_oem_water_pump_g.jpg
A5scott
May 18, 2015 06:34 AM
Savannah Buzz
Jul 21, 2011 08:02 PM
drdabbles
Aug 17, 2010 07:37 PM
Team140
Aug 30, 2009 09:41 AM
QUINCYSDISCOVERY3
Jun 8, 2008 06:50 PM
