Well, I found something in my transmission pan
All I remember from autoshop is that you are supposed to calibrate your torque wrench's before each use, I do not remember how we did it, that was a long time ago.
being wound that tight I would think it is from one of the seals around the input or output shaft. You may see it leaking fluid from there is it one of those. The outer of the seal is still a hrad metal so it may not be leaking a lot. If you see it puking it's guts out then you need to drop the tranny. The good nes is that they are easy to replace once the tranny or TC is out. Good luck, let us know what else you find out.
bosshogt
12-23-2011 11:24 AM
tornado_735
03-01-2009 09:57 PM
