Old Mar 11, 2014 | 02:43 PM
  #1391
JaySun's Avatar
Well checked all fluids (as I do every other day) everything looks fine except I was 1/2 a quart of oil low (expected since I just flushed it a week and a half ago), noticed a slight crack in the upper assembly of the right headlight looked them up online and they don't appear to have an assembly on the top...on top of this they're crazy expensive so that's a repair that's going to have to wait (j.b. weld to the rescue).
Old Mar 11, 2014 | 03:26 PM
  #1392
zeroone's Avatar
Originally Posted by Dan7
I'm going to try replacing the spring on the front wiper arms just to see if that will fix it. There's a few options for cheap wiper blades (cut-to-fit inserts or converting the mounting system for a more universal style), but that doesn't fix the lack of pressure to the windshield. Going to raid the drum break rebuild kits to see if I can find a good candidate.
Just pull the arms off.. take the "c" shaped spring retainer.. squeeze it closer together put it back together. Worked wonderfully for me.
Old Mar 11, 2014 | 03:29 PM
  #1393
Dan7's Avatar
Will give it a try.
Old Mar 11, 2014 | 04:31 PM
  #1394
jalodge's Avatar
I was thinking about doing the same thing but I couldn't figure out how the spring came out. I will try it again removing the whole arm.
Old Mar 11, 2014 | 05:25 PM
  #1395
Dan7's Avatar
Didn't have to take it off. Channel locks fit inside the arm (when pulled away from the windshield). Didn't seem to improve wiper contact though, so I bent the actual blade at the ends and that seemed to help a little.
Old Mar 11, 2014 | 05:28 PM
  #1396
zeroone's Avatar
I stuck that hog clip in a vice... lol.
Old Mar 11, 2014 | 07:59 PM
  #1397
ls1morethanyou's Avatar
i picked up a cdl from a disco 1 and a front grill, going to go install both on mine and a new water pump.
Old Mar 11, 2014 | 08:20 PM
  #1398
Dane!'s Avatar
Bought a front diff, rear u-joint, and a rear roto today...
Old Mar 11, 2014 | 11:37 PM
  #1399
Street Wolf's Avatar
Forward facing infrared illuminator. Yep.
Old Mar 12, 2014 | 09:23 AM
  #1400
dusty1's Avatar
Street, sneaky... what is the range?
