Old May 4, 2014 | 01:02 AM
  #1731
Dane!'s Avatar
No problem, just check the temp after a good drive.
Old May 4, 2014 | 01:19 AM
  #1732
ScreamingLife's Avatar
Originally Posted by pinkytoe69
Wow, you found a series on oahu...nice
We also have about a third of a D1 in the shop.
There was also a few bmw's that showed up.
Old May 4, 2014 | 07:40 AM
  #1733
ralphobell's Avatar
Originally Posted by Dane!
Discovery II drivetrain whine. - YouTube
Bad Video, but you get the point
Crap mine just started making that noise! Guess I'll start looking for a new rear diff.
Old May 4, 2014 | 11:27 AM
  #1734
jalodge's Avatar
Originally Posted by Jared9220
3)The seal is only $15 but they show special land rover tools are need to get it out. Has anyone done this repair and know if there is a way around the special tools?
Mine looked like that but it was leaking oil so I bought the pinion seal. After 2 days of trying to remove the centering pin using the socket method I gave up and poured a bottle of Blue Devil in it and haven't had a drop leak since.
Old May 4, 2014 | 02:24 PM
  #1735
Dane!'s Avatar
Drive-shafts also make a similar noise sometimes too.
Old May 4, 2014 | 08:52 PM
  #1736
ralphobell's Avatar
I checked by Drive Shaft already. Can't see anything and everything is tight. Going to check the diff's tomorrow.
Old May 4, 2014 | 09:29 PM
  #1737
ralphobell's Avatar
[QUOTE=Jared9220;461527]I was under the rover today looking at what watts bushings I needed to order and it turned out I only had a loose nut on the outside bushing and after snugging it up all was well. I love fixes like that, especially after seeing the price of those little bushings.
Jared, also make sure your vent tubes are not clogged. If they are and the condensation can build up over time and has no where to escape. It can then mix with your oil.
Old May 5, 2014 | 08:07 AM
  #1738
Jared9220's Avatar
[QUOTE=ralphobell;461684]
How would I go about checking the vent tubes? Can I just pull the tube out of the axle and blow air through it? I tend to break every plastic vent and vacuum tube I touch on this truck so I figured I would ask first.
Old May 5, 2014 | 02:43 PM
  #1739
jalodge's Avatar
I am getting a similar noise. How do I check the differential to see if that is the source?
Old May 5, 2014 | 08:09 PM
  #1740
ralphobell's Avatar
[QUOTE=Jared9220;461717]
You can try blowing through it from outside in. If you feel resistance then it's blocked. You can also remove it from the fitting and pull it out and test by blowing as well.
If i remember correctly to remove the tube you push down on the fitting and pull on the breather tube at the same time.
