Old Sep 7, 2014 | 05:50 AM
  #2181
ckadventure's Avatar
Originally Posted by cosmiccharlie
Lift installed!
Looks good!
Old Sep 7, 2014 | 04:13 PM
  #2182
redrover75's Avatar
replaced the tensioner pulley, took all of 5 minutes. tried last week and it took an hour of messing around, i suppose learning the system. I put the dayco, 89054 on, the one that is slightly smaller than the one that was on it.
Now, I need to find the 70 and 80 mm idler pulleys, does anyone have the dayco part number? Its not the 89006.
Old Sep 8, 2014 | 10:48 AM
  #2183
jdwilks's Avatar
Replace rear air bags with a used set of coils I picked up for cheap. I replace leaking set of air bags two years ago and in the last year have had each one pop decided I was done with it. Ride seems about the same to me so glad I don't have that to worry about anymore. Just need to get the light turned off (or remove bulb)
Picked up some paint and started to sand the fender flares. I did the shoe polish thing for a few years but mine are so rough that sanding them down and repainting seems like the best option to get them looking good.
Old Sep 8, 2014 | 12:15 PM
  #2184
acamato's Avatar
Plastidipped my rims & wheel arches. This photo was take before the arches. The arches look better than they did, but the still are rough.
Old Sep 8, 2014 | 10:39 PM
  #2185
mattmo78's Avatar
On the '99, I replaced a burnt out brake light and a blown fuse on the driver's seat. I think the recline motor may be going out on it. On the '04, I replaced a fuse on the passenger seat... it had blown too.
Acamoto, I like the way those wheels look when painted black... I have the same wheels and wondered what they would look like. I'll eventually do the same.
Old Sep 9, 2014 | 08:10 AM
  #2186
sDot's Avatar
What was the process for the plastidip? You just took the rubber off and sprayed, or did you sandblast the rims first?
Old Sep 9, 2014 | 08:30 AM
  #2187
ZGPhoto's Avatar
You don't even need to take the tires off, just spray the wheels and cover the tires.
Old Sep 9, 2014 | 09:04 AM
  #2188
RicketyTick's Avatar
So what's the track record for plastidip? does that stuff hold up pretty good on wheels?
Old Sep 9, 2014 | 09:11 AM
  #2189
ZGPhoto's Avatar
Not that bad, I had my car done twice with good results. The key is prep!
Old Sep 9, 2014 | 09:27 AM
  #2190
ok, I was first thinking of sandblasting the wheels and then powdercoating. I have a sand blaster and a powdercoat rig and oven that one wheel at a time will fit into. But sounds like plastidip may be the way to go?
