#2251
Well, I decided that I needed some kind of recovery point/hook with the new bumper, but I did not want to spend the $80 each on the terrafirma recovery swivel eyes. Upon inspection with this particular bumper, I noticed it bolted using 3 holes, but did not have metal on the outermost bottom hole in the chassis.
So I figured that if I cut the top of the OEM towhook bracket off on the same side, it should fit and still be sturdy. Sure enough it does and it was free. I have a second tow hook on order from ebay for $13 to get some symmetry going. So two recovery points for $13 instead of $160+shipping
(my sway bar could use some paint LOL)
#2254
Mostly I wanted some hooks in place to attach tow straps to during winter time incase either the disco gets stuck on snow/ice, or more likely, I call my son to come help me pull my RWD bmw with snow tires out of a icy bind.
Out of curiosity, what is it that you find dangerous about this? Is it that the stock disco towhook is weak because it is a welded on the bracket and could pull apart? Or is it about the fact that I cut of one of the mounting holes of the stock bracket?
I had to google Jate and it shows brackets that are held by a single bolt going through the bumper mount and my modified bracket is also going through 1 bolt mount on both sides and 2 bolt mounts on one side, so it seems about the same thing unless the strength of the weld is in question.
#2255
#2256
gaiter
Not as exciting as welding a recovery hook, but easier. I replaced the emergency brake boot/garter with a new leather one from eBay. $20 and it looks tons better. It took about an hour only because I moved slowly and gave each surface of contact adhesive 15 minutes to cure.
Measured the abs grommets that cost $50 from Falcon in the hopes I can find a more affordable replacement.
#2257
Actually the truck has 3 factory recovery points, the front is not to be used for towing, but can be used for on road recovery ei pulling vehicle onto a trailer, tow truck or pulling out of the snow. Just remember ZGPhoto is a sales man so of course he would try and sell you something. Also here is the page from the owners manual to back me up.
#2259
Please don't jump to conclusions because I work for a company that sells Rover parts. It only means I have more access to information, not that I'm trying to sell you anything.
