Old Sep 12, 2015 | 05:08 PM
  #2881
lordmorpheus's Avatar
Removed starter, checked flywheel, lubed bearings and reinstalled starter. See https://landroverforums.com/forum/di...cks-fix-75490/
Also dropped HVAC blower motor and did the yearly 3-IN-ONE oiling of that bearing as well to stop the cricket chirp on left hand turns. That has been ongoing for 4 years now. That is 4 years without having to replace the blower motor!
Old Sep 15, 2015 | 01:46 AM
  #2882
Joemamma1954's Avatar
installed underhood light assembly, that was originally on the 90's Chevy trucks. Has on/off switch and light can be pulled out 18', then reeled back in.
Light is pretty bright, but may try LED.
What did you do with your DII today?-img_4187.jpgAd
Old Sep 16, 2015 | 12:23 AM
  #2883
Clockwork John's Avatar
I'm a little late in posting, but... last weekend I let the president of the local four wheel drive club talk me into running the club's adopted trail... double black diamond, running it the easy way... I got stuck, and then I got stuck, and then I got really stuck... the trail is a ridge route, with many, many steep, loose climbs. My DII hates steep, loose climbs, and it likes to spin tires... after the third hill, I ended up with one rear wheel down in a rut, and one front wheel up in the air. Without a locking center diff, I was done. Pres pulled me out and got me to a spot where we could turn around.
The DI CDL linkage I have in my garage is going in this weekend... I told myself I was gonna wait to upgrade until I reached the limits of my stock setup... it's time... the Pres was driving a Ford Ranger, and we watched a Lexus SUV come down the trail as I struggled to make it up...
Old Sep 16, 2015 | 01:22 PM
  #2884
Changed the fluid and filter on my tranny. PO had given me new filter and gasket, unfortunately, it was the wrong one, even tho Advance Auto lists it as the right one. Luckily O'Reilly Auto parts had 1 in stock close by. While I was under there, decided to check the transfer case, it was low so I drained and refilled. Added some Blue Devil sealant, due to a very small leak.
Old Sep 17, 2015 | 01:15 AM
  #2885
Robert Booth's Avatar
Dual Battery Tray mod is turning into an epic odyssey. (no battery pun intended)
Finally got both batteries in place, with the Hood able to latch.
Next up, is installing the IBS battery system and all the extra electrical gizmo's I've bolted on. I'm racing to get the truck ready for a run down to the Oregon desert for a landspeed world record attempt at the end of the month.
Old Sep 17, 2015 | 01:18 AM
  #2886
Attachment 27438
Attachment 27439Ad
Nice! very useful little mod.
Old Sep 17, 2015 | 03:44 PM
  #2887
I really like the dual battery idea. I am looking at purchasing the Smittybuilt dual battery tray made for optima batteries(which I have used forever). I looks like it could be mounted with a few brackets to hold it into place.
Smittybilt Dual Battery Tray for Optima Batteries Part 2799 | eBay
Old Sep 17, 2015 | 07:03 PM
  #2888
Attachment 27474
The Columbia Overland tray is "bolt on" for a non facelift discovery for only 80 bucks more than that one. All of my drama was in trying to make it work with my '04. Now if you enjoy fabrication, you should take a flight up to Seattle and help me with my rapidly growing list of "todo's"
edit Just saw you have an '03 so you'd bve screwed like I was.
Old Sep 17, 2015 | 07:46 PM
  #2889
I saw the overland tray, and read about the guys making it fit(I guess it was you). At the price, I would want it to bolt on with not modification needed. At 100.00, leaves me some money for bracket fab. I don't have any need for 2nd battery, but I like it.
Old Sep 19, 2015 | 07:40 PM
  #2890
georgep's Avatar
Default It is ALIVE
Put in Big End Bearings and it is PERFECT!!
