Old Nov 19, 2015 | 02:48 PM
  #2981
OEMPartHaus.com's Avatar
Former Sponsor
Originally Posted by Robert Booth
My Rover took the family on an adventure so that my youngest could see snow for the first time.
And then my Fan Clutch died
Great picture! I wish we had snow. I just bought 6 Yokohama Geolandar I/T's on closeout and I'd like to use them.
It's 70* today
Old Nov 19, 2015 | 03:26 PM
  #2982
Robert Booth's Avatar
Originally Posted by Oasisplayer311
What size lift / tires are you running? Im going through my entire suspension now (just pressed new ball joints in). Ive always admired your set up on here!
The tires are BFG All Terrain AT's 265/ 65R 18. The lift is the OME 2" HD kit, although I need to make the time to replace my rear HD springs with the extra HD 3" springs to combat the sag I have going on from the bumper, 2nd spare tire, the rack and tent.
If I was doing this all again, I think i'd look for a set of 16"s and a smaller tire. The taller tire coupled with all the extra weight is forcing me to regear the truck.
Old Nov 21, 2015 | 03:37 PM
  #2983
Roto's Avatar
I broke the step in the back... well, it rusted through and it no longer goes back up. Time to ditch it I guess. Also took the subwoofer out and both speakers are rotten. I don't think I will be replacing the subwoofer, need ideas on what to put in there instead that's actually useful. Might add a storage caddy in there or something like that. Found that my third brake light is not working. Bulb is good, fuse for brake lights is good and the brake lights do work. Now I'm troubleshooting an electrical issue I guess... not fun. Found that A/C, even though it worked a month ago now won't come on. Bummer.
Old Nov 22, 2015 | 08:10 AM
  #2984
sstevensonm's Avatar
Very nice, where did you get directions for the mod or did you come up with it yourself?
Dual Battery Tray mod is turning into an epic odyssey. (no battery pun intended)
Finally got both batteries in place, with the Hood able to latch.
Next up, is installing the IBS battery system and all the extra electrical gizmo's I've bolted on. I'm racing to get the truck ready for a run down to the Oregon desert for a landspeed world record attempt at the end of the month.
Old Nov 23, 2015 | 09:04 PM
  #2985
It's the Columbia Overland d2 battery tray. The modification was to get it to fit in a facelift (03-04) D2
Old Nov 25, 2015 | 11:16 PM
  #2986
petminded's Avatar
Do these impact off road clearances at all?
Originally Posted by OEMPartHaus.com
Scored one of these at a local junkyard for $10 today.
Installed in about 4 seconds.
Old Nov 26, 2015 | 10:27 AM
  #2987
Yes I removed mine
Old Nov 26, 2015 | 01:59 PM
  #2988
Lupin 3rd's Avatar
Found out a P0307 was due to a cracked spark plug.
I had recently changed the wires so I'm really glad it was this and not the coils, those would have been a pain to replace.
Old Nov 27, 2015 | 08:56 PM
  #2989
Best4x4's Avatar
I upgraded the 3 168/194 bulbs in my Kalahari's gauge cluster to the Sylvania LED 168/194 bulbs and re-installed the little green bulb tops to keep the cluster green. LED's can dim, and the white needles show up much much better!
Old Nov 27, 2015 | 09:31 PM
  #2990
Roto's Avatar
I had my overheat on I-195. Great fun. Coolant pouring down on the axle somewhere on the driver's side of the engine.
