#3191
After many months of no codes, my CEL lights up and 6 codes show up. I had installed all new O2 sensors, and all codes had to do with Bank 2. Engine running rough and black smoke out the exhaust. Checked the sensors and found upstream on bank 2 had come loose and was jiggling around. Tightened it, cleared codes and they came back within a few minutes. Pulled the sensor, it was completely coated in a thick layer of carbon. Wire brushed the sensor and cleaned the grooves, blew it out real good.
Reinstalled and drove around for an hour, no codes or black smoke. Lesson learned, make sure they are good and tight.
#3193
#3194
This weekend we took the rover up to IKEA and bought a kitchen. All of our kitchen cabinets fit in the back with the seats down - 1100 pounds about maxed out the gvw but it did fine.
Also changed the oil last week and used the giant filter recommended somewhere around here. Cleanest oil I've ever seen in a car after the oil change.
Tonight I picked up some bolts and attached the coil packs where they belong. They were floating around when I bought it. I need small victories until I can spend some more time and money to track down my misfires.
#3195
I got it off Craigslist in Phoenix. Paid 400. You dont even want to know what i paid to ship it. Still cheaper than a new one. I had to strip/sand and repaint it. It looked like this before. It was white gold. The chrome had to go. I want to upgrade the mounting hardware. It seems not so good for a recovery point. My winch is waiting for me to change to synthetic rope and mount it up.
#3196
Ahh it's this one ARB Discovery II Step
I knew I liked the look of it. That's my fave ARB.
Good find.
Good find.
#3197
This disco 2 is bone stock and has 150k I think its time.
New parts are now on their way!!!!!
New suspension TF heavy Duty
New u joints Precision
New ball joints Precision
New brake lines Extended Stainless
New head gasket kit w/ bolts Proper Spec
New ABS sensors Wabsco
New ABS modulator valve Wabsco
New Tires 285/65/18 trail grapplers
New steering damper TF
Now to find the time to put everything on!!
Give me your opinion??? Is this a good start?
What else should I have done??
This is my first Discovery. Experienced knowledge is appreciated.
galchutt81 (04-21-2016)
#3198
#3199
#3200
The Rotella 15-w40 is popular due to the high ZDDP levels which is common to oils made for diesel engines. Though we dont have diesels, we do have old school flat tappet engines which require the additives to prevent wear.
As an added bonus Rotella is engineered to hold particulates in suspension so that they come out of your engine when you change the oil.
So the additives clean the insides of your engine, while the oil transports said grime out when you change.
Win / Win
Win / Win
