Old Apr 6, 2017 | 07:32 AM
  #3851
mikenac's Avatar
Refreshed the suspension with new ball joints and the terrafirma bars, finished installing the old man emu kit, and had to replace the axle boot on the passenger side. pulled the rear tail light guards and good passenger side tail from my donor disco2 and installed on my good disco2.
Old Apr 6, 2017 | 02:04 PM
  #3852
Jeff Blake's Avatar
Originally Posted by Hephaestus
Great looking truck Jeff! Glad you got it all back together. Looks like you also had to take off your stock running boards. Maybe your temps are high due to your thermostat location? Nice fire extinguisher!
Thanks. I still came up with a long list of improvements after trying it all out in the bush. rover is never done
What do you mean by thermostat location? It's in the factory location.
Old Apr 6, 2017 | 02:09 PM
  #3853
Hephaestus's Avatar
Sorry, I meant the temperature sensor you mounted after the bleeder T.
Old Apr 6, 2017 | 02:12 PM
  #3854
Jeff Blake's Avatar
The temps I posted (217-230) are from the Ultragauge.
My custom temp sensor is mounted to the left of the T (between the T and thermostat) and is always reporting 15-25 degrees lower than UG. A lower number is expected, but its hard to believe the water cools that much from the intake. I might have an air pocket at the intake sensor...
Old Apr 6, 2017 | 02:20 PM
  #3855
Hephaestus's Avatar
Dang. That's pretty hot, could be an air bubble. How does your heater core sound? Your using the 180F grey diesel thermostat?
Old Apr 6, 2017 | 02:23 PM
  #3856
Jeff Blake's Avatar
Yes it is.. was 203F before the engine rebuild (and using a regular 195 tstat) and replacing all the cooling components! Have the 180 stat now. Thankfully I have top hat sleeves, so I'm not super concerned, but I still need to get temps down. Heater is producing great heat... too much even. If I turn off the HVAC, I still get hot air coming out the footwells @ about a "setting 1" fan speed
Old Apr 6, 2017 | 02:43 PM
  #3857
The Deputy's Avatar
Did a little wheeling at the state land today. After cruising to Cleveland the day before for an engine...I'd seen enough hard surface roads to last me awhile. Anyhow. The DNR had opened a gate leading down to a boat launch. We found a little side trail leading up hill that went through the woods and took that out. Used CDL after two attempts at the hill with just traction control, but l'm unsure if it wasn't just the amount of momentum or the change in approach that helped us succeed. No matter. Funny stuff. Sorry, no pictures.
Brian.
Old Apr 6, 2017 | 04:50 PM
  #3858
Shiftonthefly1's Avatar
Jeff,
Outstanding pics. I visited OR recently and I truly felt like it was home and where I belong. Quite different from our desolate scorched earth.
Btw at 230 degrees I would have been in full panic mode. H ahah.
Old Apr 6, 2017 | 05:59 PM
  #3859
Jeff Blake's Avatar
Originally Posted by Shiftonthefly1
Jeff,
Thanks. Trust me, 230 did not feel good
The lower radiator hose is stone cold, while the return hose to the water pump is very hot (shouldn't they be basically the same after running for 20 mins?), so I'm going to try swapping in a new tstat first, even though this one is brand new...
Old Apr 6, 2017 | 08:08 PM
  #3860
Jeff Blake's Avatar
Whaddayaknow... swapped the genuine grey for a motorad 180 that I bought by accident last year... idle temps down from 221 to 201. 2k rpm from 212 to 199. Probably some air left too, maybe I'll get under 200 idle.
