#3992
Installed new-larger battery in the 01. Gone is the 660CCA...hello monster 1140CCA. Replaced ground wire to engine, now connects to motor mount bolt...which is a much larger, too. Changed over battery terminals to stud type, much easier for adding accessories. I believe this battery will be beneficial when the winch gets installed...someday.
Brian.
Brian.
#3993
#3994
#3995
Received 1,188 Likes
on
Glad they worked out, Jeff. I believe has you play around with them...they will become more useful. I like the lower portion of the strap, since it has a ring....increases your possibilities, when wanting to use a hook/bungy cord style strap. Kind of gives you more locations down low. I'll look to see if we have just the mount with an ring on it, then you could criss-cross the lower cabinet straps.
Okay, replaced 02 sensors on the 03. And all I can say is...I'm glad that job is done. Had the one on the drivers-side-front, come out with no threads. Had to repair the hole with a M18 tap. Tight quarters, for sure, but I was able to get through the inner wheel-well spacing and make the repair. Runs much cleaner and code (PO171) is gone.
Took my rover off the road for a bit, must clear my head for getting cars ready for the summer and show season.
Was hoping to get out once and do some real four wheeling, but looks like it would be until fall now.
Brian.
Brian.
#3996
#3997
on
Brian.
#3998
Well I tackled a project I'd been putting off on my Kalahari after I converted it to an 04 CDL and then disabled the INOP interlock switch (used the 04 instead).
When I disabled the old interlock switch I removed the solenoid's rod so it wouldn't be an issue anymore. However in doing so I apparently didn't seal the thing back up 100% and it leaked out of the old interlock housing. It is such a PITA to get to I kept putting it off and putting it off, but the leak wasn't going away so today I tackled it.
Lucky for me all the bolts came off without any issues (zero rust vehicle) and I was able to patiently get all 4 8mm bolts holding the old interlock solenoid off. Then I had to loosen 1 10mm bolt that held the Hi/Lo cable into place so I could lift the interlock solenoid out.
Then the real time consuming part was making a metal plate to replace the old housing. At my work we have these shims we use to level vaults/lanes with and I grabbed a few the last time I was at the shop. I centered the old interlock housing on it, drilled one hole thru it, put a bolt/nut thru it to keep it from spinning and drilled out the other 3 1/4 holes. Once that was done I clamped it into a vise and used a good old death wheel as RoadKill likes to call it and ground it down to the exact diameter as the old housing. Then I grabbed 4 shorter bolts for it, used some Right Stuff RTV sealant, and installed it.
The install went much much much quicker as I didn't have to fight getting the 4 bolts installed like I did when I had to remove them. I re-installed the brake drum assembly, the drive shaft, and washed up.
Then I took it for a 35 mile drive to town and back and I seem to have stopped the old gal from gushing like the Exxon Valdez.
It truly is a PITA to reach that old style interlock solenoid, but on my Kalahari I shouldn't ever have to worry about getting to that plate ever again!
#3999
Spent some time at Fort Fisher
So went down to the beach this weekend, instead of doing the normal Carolina Beach I felt like doing something more secluded. So we went the Fort Fisher route, showed my son how to air down the tires, switched to low range and off we went. On the way out going through crossover 1 went over a big black spot, found out later at the shop I aired up at that a brand new jeep went out and burnt to the ground because he high centered and then overheated it until it went up in flames. The deep sand at Fort Fisher was interesting. I found the truck wanted to stay in second at 2k rpm and up instead of going into third, only going 10mph, saw temps get up to 210 and started to get a little anxious. Let off just cruising at like 5-6mph and temps dropped back to 188. So I tested a theory and put it in manual since it was in low range and put it in third instead of it staying in second and engine temps stayed at the normal 188 the rest of the time. Drove all the way to the end and started to come back up. We parked for awhile and had some fun. Took my son up on the roof to show him the bay on the other side of the dunes and actually figured out you could see Southport. On the way out found a Tahoe of street tires high centered and decided to help him out, my wife was cruising my name thinking I was going to get us stuck. But anyways had a blast and have never been prouder having a Rover. Another guy with an Xterra was there trying to dig the Tahoe out, after I got him out the Xterra guy just looked at me and said, "Well I guess all you guys driving Rovers aren't stuck up, rich, ******** after all." I just laughed and told him I have met my fair share, but that most of us aren't like that.
Hope you guys enjoy the pics!
So we air down to 18lbs
It's the ocean!
If you look over there, across the dunes you can see Southport.
Justin, if you get us stuck, I'm never talking to you again!
It's the ocean!
