What size is that inverter? How did you wire it, and what size wire did you use?
looks sharp man
So now grease them!
When you grease them (this weekend, right?) don't just pump the grease gun a couple of times. Keep pumping until FRESH grease exits each of the four U-joint bearing caps. Wear nitrile gloves and wipe off as much of the excess as you can. Done forget to also grease the shaft splines. And don't forget the rear shaft.
Let us know any questions you may have.
I hit up a couple of Pull-A-Part businesses in the Atlanta area and scored for $72 Disco and Audi A6 parts:
- 2 pairs of D1 windshield wipers
- D2 air filter cover without broken latches
- 4 roof gutter corners
- 2 A-pillar trims
- driver's side rubber LR mat
- 2 A-pillar trims
