Old May 7, 2018 | 06:06 PM
  #5311
Alex_M's Avatar
Back at it again. I had a couple hours so I tore back into Frankie. Good news and bad news. Good news; I found a nicked o-ring on the oil pickup tube. Hopefully that will cure some issues. Bad news; found lots of bearing material in the bottom of the pan. Even if this fixes the oil pressure, life of the engine has been greatly decreased. Hopefully it doesn't need new bearing immediately. Pplleeaasseeeee no rod knock. Bright side, the cam still looks good from beneath and no sign of movement from the new cam bearings.
I'll report back tomorrow when I get the pressure relief valve reinstalled and what-knot.
Old May 7, 2018 | 07:03 PM
  #5312
Saturnine's Avatar
Is Frankie the newly acquired D2 or is that the one you've had for a while?
Old May 7, 2018 | 07:13 PM
  #5313
Disco_Dion17's Avatar
Originally Posted by Friday Night Disco
I picked up the grom unit and it has been working great
Do you have a link for one of those units!? I've been on the hunt for something like that for my 99 disco 2.
Old May 7, 2018 | 07:16 PM
  #5314
Saturnine's Avatar
Amazon Amazon
  #5315
coop74's Avatar
Originally Posted by Saturnine
Gonna run to the home of the depot today and make a coolant bleeding tool. Just gonna get a threaded barb that’ll screw into the bleed screw and use clear tubing to feed the coolant back into the expansion tank.
Im hoping that I haven’t been bleeding the system long enough to get all the bubbles out so doing it this way I won’t waste a bunch of coolant
That actually might be a good working solution...
Old May 7, 2018 | 07:40 PM
  #5316
Saturnine's Avatar
It makes sense to me. HD did not have a m10x1.0 barb dealio, but they are on amazon for like $10. Havent picked one up yet
Old May 7, 2018 | 07:43 PM
  #5317
Alex_M's Avatar
The old guy. Named "Frankenstein's Monster" because of how cobbled together it really is. Been with me for... 5 years now, I think? We spat sometimes, but she'll stick around a long time.
The new dame doesn't have a name yet. The little lady wants to drive it a while before she settles on a name.
Old May 7, 2018 | 11:10 PM
  #5318
Kristina McMillin's Avatar
Default Brought it home!
Let the adventures begin...
Old May 8, 2018 | 10:11 AM
  #5319
Alex_M's Avatar
Today is a sad day. Confirmed that there is a deeper issue in the engine. I got the pressure relief reinstalled and filled her up with oil. I put in a fresh out filter to confirm that wasn't the issue as well. I pulled the engine and fuel relays and cranked her over for probably 30 seconds. Went back out, unthreaded the oil filter, nothing. It's not pulling out out if the pan for some reason. I can only suspect that the low oil pressure from the nicked o-ring caused the oil pump.p to run dry and wear the cover.
Autopsy will happen in a couple of weeks. I suspect she will end up sitting; not getting fixed. The girlfriend's will get the new cam, lifters, timing set, and the heads which were decked and had a valve job done 25k miles ago. Eventually I'll pull the engine and that's when I'll decide what it's fate is to become. Ls swap? Cummins swap? Leave it built as a trail/overlanding rig? Build it into a rwd prerunner? Who knows. That'll be a ways down the road.
Of course, there is a chance I can throw a used front cover on it and run with it, but with all the bearing material I found I'm wondering if I'd even want to go that route. Maybe I'll borrow the front cover off the girlfriend's and see if that works.
I dunno. I'll keep you guys updated one way or another.
Old May 8, 2018 | 10:16 AM
  #5320
Saturnine's Avatar
Boooooo
