Old May 8, 2018 | 12:27 PM
  #5331
Alex_M's Avatar
Originally Posted by Jeff Blake
Con rod bolts are TTY, one time use.
Cheapest and best source is Turner:
https://www.turnerengineering.co.uk/...s-c102x3005626
Main bearings 25 pounds
Con rod bearings 20 pounds
Front cover genuine 245 pounds (does lucky8 sell the Britpart one? I don't know)
I underestimated piston rings.. those are actually 125 pounds
I preach turner all the time for engine parts!
Ideally you will want to inspect the crankshaft first to see if it needs turning, and order the appropriate sized bearings accordingly. Crank polish is like $40, turning it is around $100 (machinist)
Yes con rods and press fit in with a grudgeon pin. I didn't dissemble mine. Manual calls for a few special tools.
D*mn, new bolts it would be, then.
Rings must be what I'm remembering. Man, that's pricy. Would be good to find something that has the same bore size to get rings for. I'll do some research on that front.
If the crank is in poor shape I've got another. If they're both in poor shape.... I guess that would just have to add to the cost.
Getting pricy, gentlemen. We're in the ballpark of another $600-700.
I guess I'll start with robbing the front cover off the girls truck. It's gotta come off anyway. She's getting head gaskets and such anyway, so won't be any extra work on that front. Only cost one extra gasket to test.
Man, should've ordered parts right after Brexit when the pound plummeted so hard. Could've gotten all these parts for a pretty penny less.
Old May 8, 2018 | 12:28 PM
  #5332
Alex_M's Avatar
I wonder what the compressed heights of the different head gaskets are? Wouldn't mind to get the thinnest I can find. More research to do...
Old May 8, 2018 | 12:38 PM
  #5333
Alex_M's Avatar
Chevy 305 has a bore that's only 36 thousanths larger. Anyone know if you can over-bore these blocks by that much? Might run into issues there. Not sure.
Nooooow we're getting into pricy machine work.
Old May 8, 2018 | 12:56 PM
  #5334
Jeff Blake's Avatar
36 thou is a lot. Oversize (grade B) pistons were only 2 thou oversize. I wouldn't want to make those water jacket walls any thinner.
Old May 8, 2018 | 01:46 PM
  #5335
Alex_M's Avatar
Yeah, that's what I figured. And no way I'm resleeving the block. If I were to go that far I'm just getting a Turner block.
Lots of good info here:
http://www.gomog.com/allmorgan/40difference.htm
I haven't gotten to really dig into it deep yet, but I will.
Old May 8, 2018 | 01:48 PM
  #5336
Sixpack577's Avatar
Lol
The cylinder sleeves can't be much more than .036"
if they're that thick.
Old May 8, 2018 | 01:49 PM
  #5337
Alex_M's Avatar
I wonder what was so special about the Buick 300 block? The bore in those was 50 thou larger. I don't think they were even cross bolted like our Bosch engines are. I'm not positive on that though.
Old May 8, 2018 | 01:55 PM
  #5338
Davis31052's Avatar
Originally Posted by Sixpack577
Lol
I'm going 0.20 over. we will see what happens.
Old May 8, 2018 | 02:10 PM
  #5339
Sixpack577's Avatar
Cast iron block.
A different block.
The 4.0/4.6 was "based" on that design.
Old May 8, 2018 | 02:17 PM
  #5340
Sixpack577's Avatar
It's hard, if not impossible to get a sleeve wall thickness measurement of the sleeve while it's in the block.
However, they are thin.
.020" bigger is technically a -.010" thinner wall, about 2 1/2 sheets of paper thick, so not much.
But, it is substantial.
If they are boring them that much, I hope it has been done several times before...and not caused heating issues.
Aluminum disapates heat much faster than steel,
so the heat the block absorbs goes away faster than in an iron block.
