Old May 8, 2018 | 02:23 PM
  #5341
Alex_M's Avatar
Originally Posted by Sixpack577
Cast iron block.
A different block.
The 4.0/4.6 was "based" on that design.
Ah, ok. Man, what I wouldn't give for an iron block in the Disco.
Old May 8, 2018 | 02:30 PM
  #5342
Sixpack577's Avatar
lol, yeah, a little heavier, but apparently more dependable than the poorly cast aluminum ones.
Old May 8, 2018 | 02:31 PM
  #5343
Davis31052's Avatar
It's hard, if not impossible to get a sleeve wall thickness measurement of the sleeve while it's in the block.
However, they are thin.
.020" bigger is technically a -.010" thinner wall, about 2 1/2 sheets of paper thick, so not much.
But, it is substantial.
If they are boring them that much, I hope it has been done several times before...and not caused heating issues.
Aluminum disapates heat much faster than steel,
so the heat the block absorbs goes away faster than in an iron block.
He's gonna hone it out vs. boring. I'll know by the end of June. That's my ETA for having all the parts bought and reassembled.
I feel pretty good about it. Rimmer Bros wouldn't be selling a 0.20 piston if somebody wasn't having success. Might as well be me..
Old May 8, 2018 | 04:42 PM
  #5344
Alex_M's Avatar
More info. Looks like the rover 3.9 has the same bore, so in theory the rings could work. Yes? Assuming they're the same thickness I guess. If those would work, you can get 3.9 rings for less than $60 per set.
Old May 9, 2018 | 06:44 AM
  #5345
CollieRover's Avatar
It's too bad you can't just order both, and easily return the one you don't use.
Old May 11, 2018 | 08:50 PM
  #5346
lrdb01's Avatar
Default 2DIN aftermarket radio!!
Finally done!!
For those that would ask, yes it is doable. Some work, some headache dealing with the chinese customer service (useless) but definitely doable.
All stock harnesses intact but a small splice in the LH bumper reverse light wiring. Radio, navigation, bluetooth, backup camera and all radio features working even steering wheel controls.
Plus - installed an additional microcontroller with a LCD and sensors to get outside temperature, humidity, pressure and altitude. Useful when you drive around the rockies!
Happy to share the details for those interested to go down this road!
Attached Thumbnails What did you do with your DII today?-20180511_191051-2.png
Old May 11, 2018 | 09:03 PM
  #5347
rcdoeshair's Avatar
Default Absolutely
Originally Posted by lrdb01
Finally done!!
Oh, I would absolutely love more details of this mod! Thanks man, looks amazing. Oh, and btw, never thought of installing a USB port like you did, I'm going to have to do that as well!!
Thanks for all your hard work and sharing!
Old May 12, 2018 | 04:23 AM
  #5348
JUKE179r's Avatar
@lrdb01.... I am interested in what you did too. Please post as a new topic.
Old May 12, 2018 | 10:58 PM
  #5349
redrover75's Avatar
Default Actuator
Replaced the drivers door actuator, not bad. took me two hours, going slow and making a couple mistakes. Need to do the rear passenger one now. If anyone has a line on one let me know.
Old May 14, 2018 | 07:17 PM
  #5350
Jeff Blake's Avatar
Worked on the transfer case. Put together the diff with new gears, thrust washers, and an HD cross pin. Shimmed to spec
