Old 06-05-2018, 12:04 PM
Chemcorp158's Avatar
Cussed at it The Demon while adding my morning coolant. Cussed at myself for not doing option B yet when the Amigos came on after the customary 200 feet out of my driveway. I always smile for those 200' in the mornings when there are no lights on, too bad it is always short lived.
  #5442
Old 06-05-2018, 06:27 PM
razorkill12's Avatar
Originally Posted by No Doubt
Leaky fuel injector could also drop fuel pressure after cutoff.
Literally just did head gaskets and also replaced all injectors
  #5443
Old 06-05-2018, 09:32 PM
Saturnine's Avatar
Doesn't mean that an injector could be seated incorrectly or something
Maybe the hard line has a hole / crack in it on the back side of the IM?
  #5444
Old 06-06-2018, 08:18 AM
naivedisco2's Avatar
Used it to haul my new toy!!! Could definitely use some more powerful brakes but generally towed just fine. Starting to see a pattern here - now we have two V8 Rovers and a V8 boat. Had to replace a couple of things right off the bat after buying the boat... I think it will feel at home parked behind the Rovers.
  #5445
Old 06-06-2018, 09:04 PM
Sixpack577's Avatar
Tried to put valve covers on...tried.
Gaskets are junk, top front hole is punched over 3/8" off center(both gaskets, and both heads and valve covers are the same, so they are nondirectional, and gaskets cannot be flipped over).
Since the gaskets fit the valve cover, and the metal insert is pressed into the gasket for the bolt holes, and the top front doesn't line up...if you put the bolt through the hole first, there's a nice 3" part of the gasket around the bolt hole that is pushed down and out over the intake.
The whole gasket is too long too!
Another set back, and over junk parts. Yay.
Anyone else seen that before?
  #5446
Old 06-06-2018, 09:13 PM
The Deputy's Avatar
Received 1,216 Likes on 868 Posts
Switches for light bar and rear lights. Ran wires and installed three relays, one for each set of lights.
Head lights.
Head lights and brush guard lights.
Head lights, brush guard and light bar lights.
Brian.
  #5447
Old 06-08-2018, 01:55 PM
No Doubt's Avatar
Sharp! And fun! What's the skinny on the boat? Type? Price? Use?
  #5448
Old 06-08-2018, 01:57 PM
Saturnine's Avatar
Stoked.
The following 2 users liked this post by Saturnine:
Sixpack577 (06-08-2018), The Deputy (06-08-2018)
  #5449
Old 06-08-2018, 04:21 PM
jamestfl's Avatar
Donzi. 21-23 ft?? going fast...
  #5450
Old 06-08-2018, 08:14 PM
Received 1,546 Likes on 1,269 Posts
Originally Posted by Saturnine
Stoked.
Congrats man you earned that Pass
Quick Reply: What did you do with your DII today?
