Old Dec 2, 2018 | 06:00 AM
  #6151
The Deputy's Avatar
Wink
Originally Posted by Saturnine
Jeez, is that like a 8x8 square bit of tubing? What are yer plans?
That's actually what l thought...wow...that's some serious bumper material right there...lol.
I like the white walls in the garage, been on my list for two years now, really reflects the light nicely.
​​​​​​​ Brian.
Old Dec 2, 2018 | 08:00 AM
  #6152
Fastercat's Avatar
The start
Old Dec 2, 2018 | 01:24 PM
  #6153
The Deputy's Avatar
Loaded and ready for some cleaning. Steam clean the engine and underside of rover.
​​​​​​​ Brian.
Old Dec 2, 2018 | 10:46 PM
  #6154
Saturnine's Avatar
Old Dec 3, 2018 | 07:08 PM
  #6155
sickws6's Avatar
Fresh boots. Leather!
Attached Thumbnails What did you do with your DII today?-photo87.jpg   What did you do with your DII today?-photo96.jpg   What did you do with your DII today?-photo635.jpg   What did you do with your DII today?-photo613.jpg
Old Dec 3, 2018 | 08:36 PM
  #6156
mollusc's Avatar
Transferred the nearly-new springs and shocks on three of the four corners from the donor to the project truck along with putting in new EBC rotors and brake pads. Only did three because (a) one of the studs on the RR wheel on the new truck is just spinning in place so I can't get that wheel off, and (b) I couldn't get one of the nuts off of the shock tower on the donor truck. As a result, I discovered that it IS possible to remove the front spring and shock without taking out the shock tower, provided that you compress them enough.
Old Dec 3, 2018 | 10:59 PM
  #6157
Fastercat's Avatar
Little more progress
Old Dec 4, 2018 | 12:00 AM
  #6158
JoJo The Giraffe's Avatar
After hearing an odd growly sound from the front end, I found out that a bearing or something is showing its age on my 2001 Disco 2. The water pump needs to be replaced. Should be an easy thing to do this coming weekend: remove cowl, remove belt, remove pulley, drain, detach a hose or two, unbolt and toss the old pump, clean, set new gasket, bolt on new unit, and then work backwards.
Old Dec 4, 2018 | 05:44 AM
  #6159
mln01's Avatar
It's probably a good time to replace the fan clutch too. A dearly missed, long time, now long gone contributor here, Savannah Buzz, wrote many times that the water pump and fan clutch should be replaced together. As he put it, they've danced together for millions of revolutions and a new dance partner, whichever one needs to be replaced first, often causes the other one to fail soon.
Both the water pump and fan clutch in my truck are still going strong at 172,000+, but I plan to replace both clutch and pump together when it's time to do so.
Old Dec 4, 2018 | 09:00 AM
  #6160
The_OGCJR's Avatar
holy ****. You plan on having banquets at that table?
ok I’m kidding...I actually would like a wide front bumper so I had something to stand on when leaning way over the engine bay. Kinda like the big ranchhand bumpers on the f250’s
