Old 03-13-2019, 06:11 PM
Onlyrovers's Avatar
Default I didn’t break it
Today I didn’t break her!
Look out over the snow capped mountains in the desert!
  #6482
Old 03-14-2019, 03:05 PM
ATLRVRS's Avatar
Got the Disco out to the farm today. Anyone here around Atlanta?
The following 3 users liked this post by ATLRVRS:
No Doubt (03-19-2019), Richard Gallant (03-14-2019), The Deputy (03-15-2019)
  #6483
Old 03-14-2019, 07:16 PM
Jeff Blake's Avatar
Trimmed down the spare parts I keep in the rover:
- Took the voltage regulator and brushes out of my old alternator, tossed the rest. A 1 ounce tiny part vs ~25 pounds. I tried to get the rectifier/diode pack off, but it's soldered real good on there. Decided to skip that part for now... as I have 200w of solar and dual batteries anyway.
- Took the pump out of the fuel pump. Major space savings. It's actually very serviceable, all you need is 6" of 5/16 fuel line and two hose clamps (the original line is plastic and crimped on real good.. have to cut it)
I still keep a full starter motor at the moment, only because the starter in my truck is original (as far as I know). I could probably tear this part down further as it's quite heavy, but I need to do some research first on what are the important pieces of it and if a field repair is practical
  #6484
Old 03-14-2019, 09:38 PM
Twix's Avatar
You keep all that in there?!?!? I keep a booster pack, a tire inflator and a snow brush.
  #6485
Old 03-16-2019, 11:02 AM
Got p0455 after changing to the Hyundai Purge Valve. Going to swap out the hose clamp, and see if that works, or find a used purge valve to intake clip.
  #6486
Old 03-18-2019, 06:21 PM
wjsj69's Avatar
Replaced my fuel pump as a preventative maintenance measure. Replaced high pressure power steering line since it was rotted away; minutes from bursting looked like.. good thing to check if you haven't; it's behind a plastic air dam, under the radiator.
  #6487
Old 03-19-2019, 02:38 PM
Jeff Blake's Avatar
rear panhard is in
Gotta re-route the exhaust though
OverRover (03-19-2019)
  #6488
Old 03-19-2019, 05:45 PM
Alex_M's Avatar
Looks great, Jeff. Gonna clear your diff guards when both sides compress?
  #6489
Old 03-19-2019, 05:49 PM
Jeff Blake's Avatar
Not 100% sure yet. I hit a few big speed bumps and definitely heard a thunk, fingers crossed it was the exhaust...
I'd like to switch to better diff guards as well... I ripped off the rear on a trip last year
  #6490
Old 03-19-2019, 05:54 PM
Jeff Blake's Avatar
I warned the welder beforehand about it, and this is what I got. Also possible concerning is the clearance between the frame mount and radius arm bracket. Got about 4". edit: measured: 3 3/8"
Dammit I hope I don't have to move the frame mount
Quick Reply: What did you do with your DII today?
