Old May 16, 2019 | 08:30 PM
  #6641
Landy-04's Avatar
Took her out for some trail riding today had a Sanddune nearby.
Old May 16, 2019 | 11:02 PM
  #6642
Rover Rene's Avatar
Originally Posted by Pavilion
Right so finally took the pics. Got both heads done now. Just waiting for the cam and lifters to arrive and Ill put it back together.
Nice! I’m looking into buying a “mechanics special” 2001 Disco 2 but the seller says it does not run and needs new heads. If ya don’t mind me asking about how much money will you have invested in repairing the heads? Trying to calculate if it’s worth it. Thanks in advance!
Old May 17, 2019 | 08:00 AM
  #6643
The Deputy's Avatar
Thank you, for posting some pictures of a white build. Can't seem to find the ambition to start mine. It's like the old gray one sucked the life out of me...lol.
Actually, was looking at an old series last night 1967-109. Maybe it's time to do something different.
Brian.
Old May 17, 2019 | 09:01 PM
  #6644
Rover D's Avatar
4wd High
Finally got around to buying the CDL linkage for my 99 series II
Old May 18, 2019 | 12:17 AM
  #6645
MrValingo's Avatar
Made a grill out of some steel mesh. Old grill was busted up pretty bad
Old May 18, 2019 | 01:41 AM
  #6646
RossN99's Avatar
Took delivery of my new project yesterday and since I wasn’t able to push it in my garage I figured I’d get it cleaned up since it had been sitting under a pine tree for 8 months or so.
Old May 18, 2019 | 03:47 PM
  #6647
mollusc's Avatar
changed the oil in the transfer case, since that's the one fluid i haven't refreshed since i got this truck. what came out was very black, smelled horrible, and definitely not 80 or 90 weight.
fill plug and drain plug came out without any hassle at all. "this will be all done in ten minutes!" i thought to myself.
until the plastic spigot on the end of the filler pump fell off the end of the hose. inside the t-case.
meaning that i had to remove the side panel to get it out.
so i also discovered that it's a pretty simple matter to remove that panel without having to remove the chassis crossmember or the exhaust.
and that the t-case is much quieter when you put the proper oil in it.
Old May 18, 2019 | 10:10 PM
  #6648
Best4x4's Avatar
I knew someone that put ATF in their TC.... Needless to say it didn’t last very long.
Old May 19, 2019 | 02:20 AM
  #6649
No Doubt's Avatar
Installed a new motor+regulator on my driver side window. Works great, yay! Needed a T30 torx for the motor and a 5/16" nut driver for the bolts.
Now I want to mount a spare rear jerry can.
Old May 19, 2019 | 09:02 AM
  #6650
The_OGCJR's Avatar
Can you post pics of attachment or a how to?
