Old Jan 26, 2020 | 07:49 AM
  #7141
The_OGCJR's Avatar
Originally Posted by tylerhardie
Also, wouldn’t a crack behind the sleeve cause coolant to work it’s way into the combustion area and “steam clean” the cylinder it was leaking into? All of my cylinders, pistons and valves look exactly the same (high carbon buildup). Just a thought... Thanks!
correct
Old Jan 26, 2020 | 07:55 AM
  #7142
The_OGCJR's Avatar
Originally Posted by cvhyatt
Primed, installed and painted new rock sliders from Dark Crow Designs. 6 hour job which burned up my drill but they are
Etch and
Setting in placClose up of the finish so far
they look very nice! I just bought a front bumper from him recently
Old Jan 26, 2020 | 11:16 AM
  #7143
Sixpack577's Avatar
Well its certainly impressive to an IT geek like me. I continue to be in awe of all you guys who rip these engines apart every weekend and put them back together like lego blocks. As I have found out countless times, youtube is no replacement for experience!
Well, thank you, but, when my work computer doesn't act right, I can't put a wrench on it, and am in awe of the IT guy, as I try to keep up as he troubleshoots and fixes the problem.
And, you say you may not be a mechanic, but I'de have to say, you've been doing a pretty good job of faking it lately, lol.
Nice job so far on your D2.
Old Jan 26, 2020 | 11:01 PM
  #7144
Alex_M's Avatar
Finally got the wife's disco to our house, back from her family's farm, so I can begin working on getting it running again. Also picked up the donor truck her dad gave us for the LS swap into my disco. Made for a long day, hour and a half round trip each way, but I'm glad it's finally all accessible.
Old Jan 27, 2020 | 08:27 AM
  #7145
botbotbot's Avatar
New shocks and springs this weekend, front diver side spring came off in three pieces. Plasti dipped the wheels while they were off. I think it looks good!
Old Jan 27, 2020 | 08:47 AM
  #7146
NewToTheTwo's Avatar
Good question, but based on the explanation from RPI, it wouldnt think so. Seems it goes behind the sleeve and out the gasket.
FWIW though, I've never experienced this myself, but wanted to share what I learned from this vid. It answers some good questions mostly related to 03-04 issues.
You might take that gasket blow out though and compare it to the cylinders noted in the video to see if the troubled area matches their explanation.
Old Jan 27, 2020 | 08:50 AM
  #7147
Curious to know the age of your old shocks - how the truck drove vs how it drives now and which shocks/springs you installed.
Mine has 218k miles on what appear to be original shocks (but doubt it with that mileage).
Mine is more stiff/harsh vs soft and bouncy like I'd expect from old shocks.
Thanks...
Old Jan 27, 2020 | 08:57 AM
  #7148
botbotbot's Avatar
The truck has 134k on it, looked like original everything on the suspension and couldnt not find records of a replacement in the PO's paperwork. My ride was soft until there was any bumps, speed bumps or anything like that felt awful. Really jarring and stiff. I did not expect a big change in handling but I was shocked at how well its turning and handling at low and high speeds. Prior to this I had replaced the steering damper and the steering bars. It really is not a hard project, time consuming but lets you get a good cleaning in tough to reach places on the frame as well.
Old Jan 27, 2020 | 10:04 AM
  #7149
SundayFunday's Avatar
Awesome. I have a pair of the first cpl he did. I didn’t paint them properly when I received them- I guess I was too excited to get them on there. Just finishing up a week project peeling all 10 broken bolts off, stripping tons of rust off the Chanel which collected rust and debris for last few years, stripped primed and painted.
I also had to cut out & replace my driver side rocker as rust had eaten into flooring.
Now with grade 8 bolts, proper paint & good sealing, it’s coming back together. I also fabbed some 2” square stock gussets and welded back to frame.
i found that using a high lift jack on the rockers unsupported to frame just bent things..
Old Jan 27, 2020 | 10:30 AM
  #7150
boston4's Avatar
  • Replaced rear wiper motor and blade
  • Replaced gaiters on transfer case and e-brake levers
  • Installed clear indicators all around:
Next weekend hopefully I'll remove the black fender flares and the side trim on the doors.
