Old Aug 7, 2019 | 07:30 AM
  #6841
SundayFunday's Avatar
Originally Posted by COSitsWORTHit
Those look nice! I’d put some non-skid material on top of them. Either grip tape or spray
Needs good drainage.
Old Aug 7, 2019 | 09:06 AM
  #6842
Fastercat's Avatar
Originally Posted by SundayFunday
That’s awesome, I’ve often thought about fabbing rear winch with a small ATV winch size- more so for the fun of fabrication- but I’m hung up on the practicality of a scenario where needing to tug back my stuck nearly 4 ton truck with a little tiny winch.
I’d need pilot blocks to amplify & that means a looooong rope
I only plan to use the winch for pulling things onto my trailer, it’s only a 2k winch. I used to use a 1.5k on my old car trailer, seemed to be fine. I was looking in the classifieds for a 4500 tho. Lol.
Old Aug 7, 2019 | 12:06 PM
  #6843
Tod Waitulavich Christman's Avatar
Default body clips
Change out my corner bumper molding above the bumper . The plastic clip get briddle and corner molding pieces fall off. I found clips at Orlielly Auto parts ( Nissan Door panel retainers are a perfect fit and tighter than original clips.
Old Aug 7, 2019 | 01:27 PM
  #6844
Dave03S's Avatar
Nice find! I just did this job too except I got the OG clips from AB for .95 cents each.
Old Aug 9, 2019 | 02:05 PM
  #6845
Richard Gallant's Avatar
Completed the installation of both of my engine mounts, much cursing no barked knuckles
Old Aug 9, 2019 | 09:23 PM
  #6846
skucera's Avatar
Got towed home today because my starter wouldn't spin. Funny, this happened with my last Disco II five years ago, so I get to replace a starter this weekend. Yeay!!
Scott
Old Aug 9, 2019 | 11:27 PM
  #6847
Nosugar0carbs's Avatar
I’ve installed old, old man emus on the rear today, both shocks and springs, took an hour of work and much better than the stock shocks from ‘04
Old Aug 11, 2019 | 08:15 PM
  #6848
skucera's Avatar
I installed a new starter this morning, and starting is now absolutely sure. My son helped, and it was really nice to have someone to hand the starter up to to pull it up and out, and then hand down the new starter from above while I stayed under the truck. Having a helper really made this job go quickly and smoothly.
Scott
Old Aug 12, 2019 | 06:38 AM
  #6849
Got the Dorman fan and clutch, as well as ss extended brake lines online. Should arrive shortly.
Old Aug 12, 2019 | 09:25 AM
  #6850
Kalahari's Avatar
3rd Gear
Not today but over the last few weekends I've replaced the upper and lower ball joints, tie rod ends for the track bar and drag link, oil change, front axle oil, flush radiator, new thermostat, replaced plastic T bleeder with an aluminum T, master cylinder, SS brake lines, EBC rotors and pads. Next on the list is installing LK8's washer relocation kit.
