Old Oct 20, 2019 | 11:17 AM
  #6961
Sixpack577's Avatar
Perfect color, and nice job, looks great.
Old Oct 20, 2019 | 02:25 PM
  #6962
SuzSS's Avatar
Thanks! I figured the engine paint would also hold up well to GA heat and whatever I happen to come across.
Taking the picture made me realize that the headlight washer piece is missing and the passenger-side lights are taking on water! I guess that will need to be addressed next. There's always something....
Old Oct 20, 2019 | 07:18 PM
  #6963
cvhyatt's Avatar
Yeah I went ahead and added 20% coolant back.
Old Oct 20, 2019 | 07:32 PM
  #6964
cvhyatt's Avatar
Default Changed the diff and transfer fluid out
This was a complete pain in the *ss and probably the messiest job I have ever done. Because the transfer case drain plug was so close to the cross member, I had to make an adapter with enough clearance to remove it. Glad this is over. Now onto the idler pulley and cleaning up the rain gutters.
1/2 adapter cut down
Cleaning the gutters
Bearing is rattling and looks shot.
the idler pulley.
Old Oct 21, 2019 | 03:03 AM
  #6965
JUKE179r's Avatar
While you are messing about with your pulleys, check your tensioner pulley. I found my plastic tensioner pulley was so bad that I could see through the cracks and made the bearing rattle.
I replaced it with a metal pulley Gates #ER6439.
Old Oct 21, 2019 | 07:41 AM
  #6966
The_OGCJR's Avatar
the idler pulley.
Why didn’t you just remove the cross member? It’s only 8 10mm bolts
Old Oct 22, 2019 | 05:47 AM
  #6967
mollusc's Avatar
or just use a wobble extension.
Old Oct 22, 2019 | 11:30 AM
  #6968
cvhyatt's Avatar
I tried that but started stripping out the bolts. Seem like they weren’t moving.
Old Oct 22, 2019 | 11:31 AM
  #6969
cvhyatt's Avatar
There was not enough clearance for a socket wrench let alone a wobble extension.
Old Oct 22, 2019 | 04:36 PM
  #6970
The_OGCJR's Avatar
Started this the other day. I had some 11guage steel laying around so I’m using that. It is heavier than I’d like but it’s 39 lbs and I don’t have the spare on the back anymore which saves about 90 lbs so..
