Old 05-11-2021, 09:50 PM
botbotbot's Avatar
Originally Posted by mollusc
How is that different from the switch on the transfer case that tells the ECU what range it's in?
It does exactly that, only mine was broken, the one on my spare TC wasn't functional and I couldn't track one down
  #8182
Old 05-12-2021, 08:02 PM
Pete C's Avatar
Anyone know the part number for that hi/low switch and it's availability?
  #8183
Old 05-12-2021, 09:44 PM
Received 1,146 Likes on 792 Posts
I got mine for Bearmach https://bearmach.com/product/transfe...les-igm500011a easy installation an 04
Pete C (05-13-2021)
  #8184
Old 05-13-2021, 10:01 AM
botbotbot's Avatar
19mm crowsfoot if anyone is going the full replacement route. After seeing a bunch of failed ones I decided to get rid of the problem.
  #8185
Old 05-19-2021, 11:47 AM
baileyrockhound's Avatar
put her on 33s, lving in colorado I was afraid the power would be way down, but it has no issues running 6-8 percent grades at the posted speeds or above at altitude.
The following 2 users liked this post by baileyrockhound:
ckadventure (05-20-2021), Daytoman (08-19-2021)
  #8186
Old 05-19-2021, 11:48 AM
mounted a new gps tablet to run onx offroad and gaia navigation
  #8187
Old 05-20-2021, 10:38 AM
DiscoJunction's Avatar
Hi,
I am new to the Land Rover world, but I saw your post with the picture of your 33's. Would you mind telling me where you got the lugnuts and the wheels? Also what brand and size of lift do you have to accommodate the 33's? I got a 2004 Disco G4 Edition that I am slowly building!
The following 2 users liked this post by DiscoJunction:
ckadventure (05-21-2021), Daytoman (08-19-2021)
  #8188
Old 05-20-2021, 10:56 AM
wheels and lugs nuts are stock 2004, i pulled the silly stainless caps off the oem lug nuts, i hit em with some cleaner and a wire wheel, they are getting dirty again though, when done you need to locate a 26mm socket to change tires
the rig is sitting on a 3 inch TF heavy duty lift, with HD tie rod, HD drag link, extended SS brakelines and abs lines, custom made caster plates,
  #8189
Old 05-20-2021, 11:16 AM
Thanks! That's very helpful!
  #8190
Old 05-20-2021, 11:21 AM
Do you know what numbers on your TF springs. I bought a donor 2003 Disco2 for the seats and it ended up having a TF lift. The springs have numbers on them. The Passenger side rear has "TF027V PS" The driverside rear has "TF027V D/S" and the fronts have "TF 052 PS" and "TF 052 DS". Are these what you have?
Quick Reply: What did you do with your DII today?
