It does exactly that, only mine was broken, the one on my spare TC wasn't functional and I couldn't track one down
Anyone know the part number for that hi/low switch and it's availability?
I got mine for Bearmach https://bearmach.com/product/transfe...les-igm500011a easy installation an 04
Hi,
I am new to the Land Rover world, but I saw your post with the picture of your 33's. Would you mind telling me where you got the lugnuts and the wheels? Also what brand and size of lift do you have to accommodate the 33's? I got a 2004 Disco G4 Edition that I am slowly building!
wheels and lugs nuts are stock 2004, i pulled the silly stainless caps off the oem lug nuts, i hit em with some cleaner and a wire wheel, they are getting dirty again though, when done you need to locate a 26mm socket to change tires
the rig is sitting on a 3 inch TF heavy duty lift, with HD tie rod, HD drag link, extended SS brakelines and abs lines, custom made caster plates,
Do you know what numbers on your TF springs. I bought a donor 2003 Disco2 for the seats and it ended up having a TF lift. The springs have numbers on them. The Passenger side rear has "TF027V PS" The driverside rear has "TF027V D/S" and the fronts have "TF 052 PS" and "TF 052 DS". Are these what you have?
