Old Oct 2, 2022 | 11:23 PM
  #8941
andino's Avatar
Originally Posted by rynoman1
I installed a flokooler and have the allisport radiator and it did not change the temps. Personal experience dont waste the money.
I think part of my issue is running with an RTT and heavy steel wheels/MTs in 33s. I had better temps prior to the swap and this new Nissen's rad. Figured having more capacity would help but maybe it's the wrong path.
Originally Posted by Discorama
Temperature is restricted by the thermostat as well. If you didn't replace it, temps won't change much.
I'm running an inline 180F from Extinct. I had much lower temps before but lately, things have been creeping up and I'd just like a little more capacity overall so I'm looking at options to increase capacity. I used to run 177-182F all day with A/C and 90F+ when I had the stock bumper and 31.5s. But with all the added gear, seems like living with the higher running temps might be a fact of life. Not sure.
Old Oct 3, 2022 | 07:12 AM
  #8942
sirapplesauce's Avatar
5th Gear
Default Newbie question
i upgraded my entire suspension, currently my disco 2 is sitting on a 3" lift but i want to up my tires from 30's to 33's
i am not hardcore off roading in this car, mainly as a daily driver
do i need to upgrade my gears for bigger tires or should i be fine?
if i have to, should i just get 4.75 even though i'll be running 33's or should i go for the 4.37 if i have to change gears?
Old Oct 3, 2022 | 11:42 AM
  #8943
andino's Avatar
You’ll get some more visibility if you make your own thread but I’m running 33s with 4.12 gears as many other do here with good success. Because of my running gear, I probably should have opted for 4.37 but I couldn’t imagine running 4.75s with 33s. I do about 2570/2600 rpm at 70ish mph with 33.1” tires and 4.12 gears.
Old Oct 5, 2022 | 12:45 PM
  #8944
whowa004's Avatar
4.11/4.12s are perfect for 33s. I don't know anyone that's really happy running 4.37s with 33s. My classic runs 35s and 4.11s and it still turns them just fine..
Old Oct 5, 2022 | 08:08 PM
  #8945
Greg_M's Avatar
For your consideration:
Old Oct 13, 2022 | 11:45 AM
  #8946
Dervish's Avatar
Finally got my worklights done, just need to align them properly at some point.
The ones to the sides, on the front doors are operated on a remote.
Not too bad for a ~2x2" led light worth ~25 EUR per piece.
Old Oct 13, 2022 | 09:17 PM
  #8947
Alex_M's Avatar
Last day/late night thrash to get "ready" for URE tomorrow. Got my diffs in, but the air system isn't wired and I'm missing a couple fittings. We also had to get my buddies bumper (left) built so he had front recovery points.
I'm dealing with some motor issues, throwing a code for valve timing error so I'm trailering down in case of a failure.
Not as prepared as we'd like to be, but should be a fun weekend none the less!
Old Oct 14, 2022 | 08:21 AM
  #8948
disco96sd's Avatar
"ure" ?
Old Oct 14, 2022 | 08:58 PM
  #8949
Alex_M's Avatar
Uwharrie Rover Expedition, put on by the Old North State Land Rover Society. We made it in around 7.30pm finally. Set up camp, made some food.
Old Oct 14, 2022 | 10:43 PM
  #8950
disco96sd's Avatar
is that in the ukraine ?
