Old Oct 12, 2023 | 09:18 PM
  #9441
redrover75's Avatar
Default O2 Sensor
I had an elective O2 sensor replacement that quickly got out of hand. It worked, only occasionally there was a stumble in the idle and Torque would show the Bank 1 sensor not sending any info.
Knowing it was a 20 year old sensor, I still managed to under estimate the challenge.
Five days of constant penetrant sprays
One bottle of propane
Two O2 sensor wrenches
Three broken hose clamps to shore up the O2 sensor wrenches
Pipe wrench, channel locks, vice grips, impact sockets, 30" of extensions
It was simply galled into place. The technique of going a few degrees and reverse and forward with spray seemed to make the difference. But who can tell after all the chemicals, heat and brute force what really did the trick.
I finally go it out. Definitely cut the wires once you decide to replace it, much easier. I even dropped the exhaust gain some room. Amazingly none of those bolts snapped.
I need to learn to leave well enough alone.
)2
Old Oct 13, 2023 | 04:39 AM
  #9442
Extinct's Avatar
I feel you, I have one coming up that I will need to do. Which Penetrant did you use, Aerokroil is the best by long ways in my opinion for these situations. My patience is much shorter than yours though, I am already considering having the muffler shop weld in a bung.
Old Oct 13, 2023 | 10:27 AM
  #9443
redrover75's Avatar
Default Penatrat
I used aerokroil and a silver can, I forget the name. It's better than PB blaster. Knowing what I know, I would just cut it w a grinder and use an impact from above. Atleast to loose. It enough to get some penetrant in there. It could gall the threads if you used the impact to remove it all together.
I had no threads left on the sensor but luckily the exhaust was fine.
Old Oct 13, 2023 | 10:20 PM
  #9444
04disco2va's Avatar
Pulled headliner, resealed sunroofs, fixed drains (one completely snapped off).
Still leaking above windshield. Found one more possible cause…and I didn’t think I had any rust !
Old Oct 14, 2023 | 08:03 AM
  #9445
sickws6's Avatar
Default Flex plate!
Old Oct 14, 2023 | 09:13 AM
  #9446
Harvlr's Avatar
What was your clue that the flex plate had issues? I’m a bit suspicious of mine in the P38, as I have a slight vibration that is sometimes there. It’s RPM related, not vehicle speed, and it seems to disappear on torque converter lock up.
Old Oct 20, 2023 | 07:34 AM
  #9447
sickws6's Avatar
No symptoms until it sheered and then didn't have any drive.
Old Oct 20, 2023 | 01:30 PM
  #9448
Roont's Avatar
Originally Posted by sickws6
That sucks! Happened to my dad when he was pulling a boat, same area came apart! Hope you got home safe after that
Old Oct 20, 2023 | 02:26 PM
  #9449
Harvlr's Avatar
Ok thanks. My vibration isn’t enough for me to tear things apart to look without a bit more of a definitive reason. It’s just not as smooth as the Disco. ​​​​​
Old Oct 21, 2023 | 04:57 AM
  #9450
Extinct's Avatar
Originally Posted by 04disco2va
P
Digging the seats, where did you get those?
