#9201
Relays are known to be kind of wonky over on these. Also, anything not original like the distributer or ignition coil can be problematic. Don't let your friend get fooled into newer or aftermarket dizzys. Find good used 35D bosch units I believe they are and stock up on em lol. The classics are just different enough from a d2 that it's a totally different ball game tho it's the same block.. Good luck!
#9202
#9204
#9206
The rubber, eraser material wheels are probably a better bet. I am sure you have tried gasket remover, maybe a torch to soften it?
I just carefully used a razor and back scraped it, but yours looks worse.
good luck with it, I hate when a simple job takes hours longer than it should.
DiscoID (03-22-2023)
#9207
I got it, finally, using Jasco premium paint and epoxy remover and back scraping with a contractor's razor. Those of you not in California are luck because you can get the original Jasco while we can only get the non-methylene chloride version which is nowhere near as effective.
I learned about Jasco from a friend who is a long-time Rover mechanic.
#9209
