#9391
#9392
#9393
Rushed to install my Ashcroft CDL linkage so I could get the D2 out this past weekend with friends. Camped and explored southeast of Greenwater, WA. I need to get into the habit of taking more pictures and video because there were some good moments where the D2 did its thing, but this boring still is pretty much the only one I got.
Mt. Rainier was looking great.
#9394
#9395
Driveshaft in, battery cables repaired! Drove it for the first time since driving it home. Much better without shredded driveshaft noise haha.
Rear window regulator guides (the part glued to the glass) came off with regulator. Going to remove glass, clean, re-adhere.
AC still blowing cold, guess it's a small leak, will keep checking for dye.
Found rear seats and hardware on eBay!
I started to do the pcv mod, but realized it had been half done. The 'new' valve was installed in the intake but the baffle in the tube in the valve cover was broken off and still in there. Thanks again to this forum, I got it out and put the hose back on.
Next is registration and emissions. Readiness is set so hopefully.... Haha.
Going to use the post on here about the high mileage service (thank you to whoever put the shopping list together!) And chip away at that.
31 or 32 in tires will be my reward to myself beginning of the New Year if I get this thing as reliable as I can (hahahaha)
#9396
Played around with my new L8 disconnects today. A 2 inch lift arrives tomorrow so I wanted some before shots. Connected, without the CDL cause I forgot, the thing climbed nearly 26 inches high before I lost traction. Disconnected it climbed nearly 30 inches before losing traction with the CDL. The rear swaybar is still installed and connected in these pics. Also included a pic of the rear tire fully stuffed. It's a brand new 265/65r18 Nitto Ridge Grappler and it's close but doesn't touch anything.
The following 4 users liked this post by WastedAccounts:
#9397
The following 6 users liked this post by PeteDub:
Gripen (09-01-2023),
Roont (09-02-2023),
T-rex (09-02-2023),
WastedAccounts (09-02-2023),
whowa004 (09-02-2023),
and 1 others liked this post.
#9398
wjsj69 (09-04-2023)
#9400
@WastedAccounts Pro tip: Take your old front sway bar links and put them on the rear sway bar for and additional 2 inches of travel in the back. It's a free mod.
The following 3 users liked this post by donniefitz2:
